Omega 2.2 petrol 2003 excessive pressure when oil filler cap removed at idle
Started by Andy A, 04 January 2015, 11:09:04
Andy A
Quote from: Taxi Al on 04 January 2015, 19:22:40
Quote from: Andy A on 04 January 2015, 19:16:17
Quote from: Taxi Al on 04 January 2015, 18:09:07
Once warmed up, what is the temp gauge showing?
Just run the engine up to temperature and its around 92 deg max.
Ok, that sounds pretty normal... lazy thermostat and consequent cool running kills the fuel economy, but, that said with the lower temps lately... does the 2.2 have a separate ECU temp sensor?
Not sure. How can I tell?
Quotedoes the 2.2 have a separate ECU temp sensor?
Yep
QuoteNot sure. How can I tell?
Rear of engine by EGR. One sensor for the dash gauge, t`other for coolant temp.
Rear of 2.0ltr in pic, 2.2 same minus the DISPACK
Andy A
Quote from: RobG on 04 January 2015, 19:45:17
Yep
Nice one Rob. Do you know if "My Naff Code Reader" software will be able to tell me if the ECU temp gage is working correct?
It should raise a code... P0115 iirc ;)
Won't solve the crankcase pressure, but might help the economy...
Andy A
Quote from: Taxi Al on 04 January 2015, 20:16:26
Thanks Al, I'll borrow a laptop in the week and see what comes up.
Do you know how much crankcase pressure is acceptable if any?
Can't help there :-[ There will always be some pressure, but a lot of variables once time and wear are factored in...
plym ian
Mines about 18-19 round town so nowt to worry about and as petrols getting cheaper who cares ;D
The Sheriff
Quote from: plym ian on 04 January 2015, 20:52:16
Vlad.  ;D
flyer 0712
Whats the mileage of the car and has it ever had a head gasket replaced  :y
Head gasket failing won't pressurise the crank case.
Is the cam timing OK?
Oil consumption up?
Andy A
Andy A
Quote from: flyer 0712 on 04 January 2015, 21:19:43
The mileage is 115000 and I don't know if the head gasket has ever been done.
Andy A
Quote from: Marks DTM Calib on 04 January 2015, 21:53:08
Head gasket failing won't pressurise the crank case. Could you explain what will?
Is the cam timing OK? Checked the timing this morning and all is still aligned correctly.
Oil consumption up? No. It hasn't used any oil at all.
Andy A
Is there a PCV valve on my 2.2 petrol 2003 and where will I find it?
Thanks
