That moment......
Started by Gaffers, 05 January 2015, 15:45:01
Gaffers
....when a fault has been bugging you for a while and you could not understand it.  Then you have a eureka moment while you calm down and realise how silly and obvious it was..... :-[
I installed a little PIR sensor for the light on the porch.  Fitted a 4th line so that I can over ride it with a switch.  All very simple and tested in twilight all ok.
Then it was constantly on every night regardless of the settings I tried.  During the day it functionned as it should (ie stay off) Convinced I had a duff PIR I was about to send it back for a replacement until I had a theory which I tested and proved correct.  So simple I nearly smacked my head against a wall.
What do you think was wrong?  Just for the record, the PIR and settings were completely fine.  Let's see how clever you are ;D
Auto Addict
It's that obvious, it's not worth mentioning ::)
I like red cars
Switch was on the wrong side of the sensor... :-\
Terbs
I've read it, and re read it. turned it over in my head a dozen times. I am having to give up.........I don't know what a PIR is  ???
Webby the Bear
Need to remove the cellophane from the sensor  ;D
Thats also just a guess cos ive no idea what a PIR sensor is either  ;D
RIP Paul Lovejoy
Gaffers
PIR = Passive InfraRed sensor (although that might give it away ::))
The type that knows if you walk in front of it. :y
Auto Addict
Passive infrared sensor.
Beat me to it! ;D
I like red cars
Gaffers
Quote from: Taxi Al on 05 January 2015, 16:34:00
Nope, wiring at the switch was fine as was the wiring at the PIR and the light.
Auto Addict
Quote from: Monsieur Guffer on 05 January 2015, 17:00:57
Still obvious ::)
I like red cars
Gaffers
Quote from: Auto Addict on 05 January 2015, 17:01:40
Still obvious ::)
Clearly not ;D
The light (or a.n.other heat source) pointing towards it
Either next to porch light or boiler exhaust...
Quote from: Monsieur Guffer on 05 January 2015, 15:45:01
I thought virtually all PIRs had an override by turning on-off-on in quick succession
plym ian
The pir wasnt connected to the light  ::) ::)
Plants, trees or bushes moving within the line-of-sight ??
