Author Topic: pug expert  (Read 2924 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
pug expert
« on: 05 January 2015, 18:15:04 »
pug expert / citreon  dispatch / fiat scudo, 1.9 d. I believe they are the same vehicle just different badges. the indicators on my sons Peugeot has stopped working . all fuses ok . was advised to change hazard warning switch by Peugeot , this has,nt worked. I suppose it means it must be the flasher relay or the column control is at fault. if anybody has had a similar prob with one of these, I would be interested to know what the fix was.  :-\ :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: pug expert
« Reply #1 on: 05 January 2015, 18:18:28 »
I had the same problem on the mig andreplacing flasher relay fixed it. if that helps
RIP Paul Lovejoy
raywilb
    • Citroen C4 Cactus
Re: pug expert
« Reply #2 on: 05 January 2015, 18:23:29 »
pug dealers advised to change switch, in this case it hasn,t worked
AndyRoid
  • Hants
Re: pug expert
« Reply #3 on: 05 January 2015, 18:23:56 »
There aren't many things that stop the indicators working, and you've already changed one of them so it's either going to be down to the flasher unit or the indicator switch.
Webby the Bear
  • Northampton
Re: pug expert
« Reply #4 on: 05 January 2015, 18:25:23 »
+1
RIP Paul Lovejoy
raywilb
    • Citroen C4 Cactus
Re: pug expert
« Reply #5 on: 05 January 2015, 19:06:32 »
yes its as you have stated , problem is the pug dealership advised wrong. a trip round the local and hope I can find something intact, as  the ebay sellers tend to gut them. Cheers anyway   :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: pug expert
« Reply #6 on: 05 January 2015, 20:48:38 »
The indicator stalks are a known problem on those vans although it usually affects one side.
other rides
hoody
  • Scotland
Re: pug expert
« Reply #7 on: 05 January 2015, 22:00:51 »
changed loads of the relays on my mates taxis,panel off below steering and the light grey(cartier) relay is the boy.
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: pug expert
« Reply #8 on: 05 January 2015, 22:06:21 »
It's a mix of French and Italian electrics; smoking the wrong brand of cigarettes in the van could cause the problem.
Re: pug expert
« Reply #9 on: 06 January 2015, 12:24:21 »
.. or failing to provide the fog of Gitane smoke that the electrics is accustomed to. At least this masks the smell of the fuse box melting. :D
henryd
  • west cornwall
Re: pug expert
« Reply #10 on: 06 January 2015, 17:43:43 »
Thought it was Omega's that caught fire,not Frenchys finest ??? ;D ;D
other rides
The Sheriff
Re: pug expert
« Reply #11 on: 06 January 2015, 18:04:04 »
Ohhhhh nooooo. Not on this forum, Enery  ;D
Page created in 0.024 seconds with 20 queries.
