OOF members in Leeds?
Started by Shackeng, 06 January 2015, 11:30:27
Steve B
Shackeng
Quote from: TheBoy on 07 January 2015, 18:46:27
White bits are the cases from the original GM switches. Black are the Farnell bits
Which look like pins and no holes, now check their website data sheet tech.drawing, which clearly shows holes in lugs!
Steve B
Quote from: Shackeng on 07 January 2015, 19:07:38
We are talking about the two holes on the black one and the fact that the VX one has the 2 locating pins on each side of the switch case are we.
Shackeng
Quote from: BIGtime on 07 January 2015, 19:19:32
I'm talking about the metal connecting lugs or pins, 3 x off, which require soldering  in place. :y
Steve B
Ive got plenty of the RS ones due to arrive here with the proper solder pins hopefully
I think we're confusing the 3 connecting pins on the bottom with the 2 mounting holes on the side, which are lugs rather than holes on the originals.
I've never found replacements with lugs, by the way. I find they are adequately secured by the solder joints, though.Well, none have failed yet. ;)
Steve B
Quote from: Kevin Wood on 07 January 2015, 22:11:43
Noticed that kevin.. Them TB shows are only Available from RS...The one you used in your guide is the other one with the green press button  :y
CaptainZok
I suppose it you want to be fussy a bit of plastic rod superglued through the holes would give you the lugs back but as Kev says they seem to work fine without.
TuBy's new whipping boy.
Steve B
Quote from: CaptainZok on 07 January 2015, 22:41:00
Its not the rods its the connections that fit on the PCB
No good  :y
moggy
Quote from: BIGtime on 06 January 2015, 20:15:39
Quote from: Shackeng on 06 January 2015, 19:57:22
Quote from: Mr Gav on 06 January 2015, 17:37:54
I`m in Leeds if you want me to get you some  :y
Thanks very much for the offer Gav, however I'm going to get the Farnell ones from Moggy who can order them direct. An RS one I fitted last year has failed. :y
As usual OOF comes up trumps, thanks to all for your offers of help. :y :y :y
That never lasted long
Hi Shackend,you have PM Dean.
