Author Topic: Reading Lights On  (Read 7905 times)
Drewomega
  • Aviemore and Mallorca
    • SKODA Octavia Scout 2.0
Reading Lights On
« on: 07 January 2015, 10:52:55 »
Hi Guys,
A happy new year to one and all.  :y
After being away for 4 months the Omega started up first time, no problems.
However, last night I jumped out of the car and the reading light failed to go out. There are four lamps in the unit, I faffed around with it and as it was dark and raining I disconnected the battery. This morning I reconnected battery and the lights went back on. It is the back 2 lights in the unit that are on.
Anybody any ideas?
Thanks in advance guys.
I'm always last in the office in the morning but I make up for it by leaving first.
Re: Reading Lights On
« Reply #1 on: 07 January 2015, 11:04:34 »
Headlight switch not pulled out slightly :-\
Drewomega
« Reply #2 on: 07 January 2015, 11:28:04 »
Hi Al. Just tried that, still the same. I don't know which is the reading lights and which is the door lights.
« Reply #3 on: 07 January 2015, 12:14:21 »
Reading lights only switch on using the buttons on the light unit :y
Drewomega
« Reply #4 on: 07 January 2015, 12:42:26 »
Just plugged unit back in and the reading/map light switches do not work either. Which 2 lamps are the courtesy ones and which are the reading map lamps?
« Reply #5 on: 07 January 2015, 12:44:01 »
Reading ones are the small spots
« Reply #6 on: 07 January 2015, 12:52:35 »
.... and which is the door lights.
the lamps that come on when you open the door  ::)
Drewomega
« Reply #7 on: 07 January 2015, 13:00:52 »
LOL! Right! I have managed to get the reading lights to work and they are the front 2 lamps. So the back 2 lamps and the spots must be the courtesy lights. It is the back 2 lights I am having the problem with staying on.
« Reply #8 on: 07 January 2015, 13:20:20 »
The manual switch on the rear lights has three positions, OFF, ON, and ON when door opens.
« Reply #9 on: 07 January 2015, 14:15:25 »
he means the rear lamps in the front courtesy light ........ not the lamps in the rear of the car .....  I think  :-\
Drewomega
« Reply #10 on: 07 January 2015, 14:35:37 »
Correct AndyB. A cluster of 4 lamps are in the front courtesy light with I think a motion sensor. It is the back 2 lamps in the cluster that are staying on.
Drewomega
« Reply #11 on: 07 January 2015, 17:44:17 »
These are the lamps that are staying on all the time. I have since taken the lamps out to save my battery.
Any suggestions as to the problem would be much appreciated.  :y
« Reply #12 on: 07 January 2015, 19:00:53 »
....  with I think a motion sensor.  ....
the silver bit in the middle? That's a microphone for a phone  ;)
Sorry, can't help with the courtesy lights staying on other than a duff light unit  :-\
« Reply #13 on: 07 January 2015, 19:13:33 »
Have you tried lightly cleaning the PCB with switch cleaner, or could possibly be a dodgy switch on driver`s door pillar
« Last Edit: 07 January 2015, 19:15:29 by RobG »
« Reply #14 on: 07 January 2015, 19:15:25 »
Sorry, can't help with the courtesy lights staying on other than a duff head light switch   :-\
Fixed :y
If the reading lights work, then there's only one thing left...
