Carpet cleaning
Started by Sir Tigger KC, 10 January 2015, 20:04:08
flyer 0712
I think pop eye killed olive  by stuffing spinach down her throat ;D ;D
Terbs
I'm in Dorset at the moment, Steve....if you need more spit, me and swmbo will pop over :y
Quote from: terbert on 11 January 2015, 12:18:22
Thanks Tony, but I'm in South Wales, which is a bit of a way for a spitting party!  ;D
Terbs
Have you moved there, mate, or just visiting :)
No it's a place that I rent out, where the tenant did one and left it in a bit of a state.  >:(  ::)  Hey ho....  ::)
Anyway the ice worked a treat! I made a big block last night in a marg tub, sat it on the gummy patch for half and hour and then gave it a good scrub and it's all come out!  :y
OOF to the rescue once again!!!  :y :y :y
Quote from: Sir Tigger on 11 January 2015, 17:29:36
Did you have to scrub whole carpet to get it to match ;D
I'll see tomorrow when it's all dried out, but yes I might have a very clean patch!  ::)
Should be good though, it's dark brown with a speckle in it, so it hides a lot of abuse!  ;)  :y
Quote from: Taxi Al on 11 January 2015, 01:02:17
Freezing potentially damages the pile/fabric as you get a solid block containing both sweet and fabric... Spit is free and guaranteed to work every time :y
Not if done properly,................ ;) :y And if spit removed chewing gum why are there so many products on the market?................ :-\ :-\
Result.............. :y :y
Quote from: Vamps on 11 January 2015, 22:19:55
Snake oil mostly :y
I didn't spend the thick end of 8 years cleaning planes without learning summat useful... ::)
Quote from: Taxi Al on 11 January 2015, 22:37:16
Snake oil mostly :y
I too have a background in cleaning, mostly commercial / industrial though.......... ;) :y
Don't feel 'slighted' Al, I was keeping the spit method in reserve!  :y  ie I'd have probably spat on it in disgust if the ice hadn't worked..  ::)  ;D
Quote from: Sir Tigger on 11 January 2015, 23:38:34
Simplest ideas and all that... ;D
jerry
Quote from: STMO on 10 January 2015, 21:28:28
Quote from: Sir Tigger on 10 January 2015, 21:21:09
I think I'll try the ice before the spit....  ::)  :y
Keep 'em coming lads!!  :)
Cut out a square foot of carpet with a sharp knife and replace it with a piece from under the sofa. :y
Thanks STMO, made me laugh  ;D ;D ;D
