Author Topic: few faults, any advice ?  (Read 2283 times)
bigjono
  • crewe cheshire
    • omega 2.2 saloon 52 plate
« on: 17 January 2015, 10:12:41 »
had my omega 3 months now , its a 2.2 on a 52 plate with 49,000 on clock, got a few niggly faults just need a few suggestions where to start looking,
1, boot opens off the remote but not on the switch on dash, fuse? switch? any way to test to find fault,
2, it runs great but seems a bit flat to me, need to tow my caravan soon so going to investigate, seems like its missing/pinking when rev it on low revs, and when pull away in 1st gear seems flat then kicks in all of a sudden, making it jerky to drive, iv cleaned egr , im thinking MAP sensor as ive read this is linked to timming i.e advance/retard ? any ideas where this is ?
Re: few faults, any advice ?
« Reply #1 on: 17 January 2015, 10:28:06 »
1) Have you tried pressing holding switch for 3s? Or if the earlier ECU, the key has to be out of the ignition, then a quick press.
2) Ideally needs some live data around MAF/Lamda/trims to see whats going on.
bigjono
  • crewe cheshire
« Reply #2 on: 17 January 2015, 12:51:08 »
wey hey we have boot fixed, thank you 3 secs as easy as that,
 still cant find the map sensor tho
« Reply #3 on: 17 January 2015, 14:57:06 »
MAF
bigjono
  • crewe cheshire
« Reply #4 on: 20 January 2015, 19:23:14 »
looks a bit different to mine.  :-\ mines a diesel.. found and cleaned map sensor.. any other little things to clean or firtle with
« Reply #5 on: 20 January 2015, 19:29:54 »
If you would have mentioned that fact I wouldn`t have posted a pic of the petrol 2.2 ::)
