Author Topic: Traction control  (Read 2751 times)
combatkev82
  • bridgwater, Somerset
  • vectra b gsi ph 2 rep/seat mk1 cordoba sx 2 coupe
    • 2000 2.5 v6 ELITE saloon
Traction control
« on: 20 January 2015, 14:46:12 »
Afternoon all
 lights like normal an the old slug spun its wheels up .
then seen on dash the tc light was on , didn't think anything of it as thought a mate had turned it off early ,
so switched it off an it came back on an wont turn off now . not a big problem but as not the best weather at the mom could be .
any body had this before
cheers kev :-X
Living The Dream
Re: Traction control
« Reply #1 on: 20 January 2015, 17:58:54 »
Is the speedo working? TC light on as well?
combatkev82
« Reply #2 on: 20 January 2015, 20:18:52 »
yeah everything works as it should , an TC light on like normal an TC off , so all working , it just wont turn back on
going to have a look on weekend now , an see if switch dirty an stuck on .
Love the car , but every day i drive it i find another problem to sort .
cheers :'(
Living The Dream
« Reply #3 on: 21 January 2015, 11:59:00 »
Does sound like a sticky switch :-\ easy enough to remove and test it :y
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #4 on: 21 January 2015, 12:01:56 »
Can't think off hand which ones would be suitable - I assume most of them, but you just want to pop another switch out and swap it, to eliminate / prove it's the switch at fault.
« Reply #5 on: 21 January 2015, 13:14:58 »
Sounds more likely that there is a fault related to the TC. Might be worth checking the ABS/TC ECU for codes.
« Reply #6 on: 21 January 2015, 18:55:06 »
Wot he says :y
Doubt its the switch, which is a simple PTM, non latching
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #7 on: 21 January 2015, 18:58:16 »
Traction control is for wimps  ;D ;D
says me who nearly ended up sideways on a greasy roundabout this evening :-\
« Reply #8 on: 21 January 2015, 18:58:54 »
I did. With TC enabled.
« Reply #9 on: 21 January 2015, 19:03:09 »
I haven't tried that hard, but even with the TC off, the Insignia simply refuses to let go...
