Author Topic: GPS laser change NCDC 2013/15  (Read 6062 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« on: 22 January 2015, 17:01:28 »
How hard is it to change the GPS laser unit in the NCDC 2013 head unit as they are only £25 plus postage on the bay of flea.
Re: GPS laser change NCDC 2013/15
« Reply #1 on: 22 January 2015, 17:10:25 »
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #2 on: 22 January 2015, 17:22:35 »
Seek and you will find
http://www.omegaowners.com/forum/index.php?topic=127181.0
Thanks Rob, looks like a lot of work to me, but it's that or find another head unit but with a CID ( non Bose for the MV6)
Zirk has one set to Bose but it's the 2015 with phone.  :-\
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 22 January 2015, 18:39:23 »
Just to clarify the above mentioned Units is Non Bose  ;)
I do have a 2013 plus CID (No Phone) but that one is Bose.
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #4 on: 22 January 2015, 19:30:58 »
But the Bose can be turned off with Tech2, or that's what I understand from TBs reply in my other post.
Zirk PM incoming.
Zirk your in box is full, how much for the Bose unit and CID. Send me a PM
« Last Edit: 22 January 2015, 19:33:49 by joff »
amba
  • Medway towns
    • German V6
« Reply #5 on: 23 January 2015, 08:27:21 »
Had laser replaced on my H/U some months ago as having issues reading navdisc.
By all accounts H/U has 2 lasers ..1 for navdisc and 1 for cd player...Got mine from Gerbers and although had the offer of it being replacred by a forum member was worried about sending unit by courier.Found local specialits who charged £50 but he did say it was a fiddly job .
« Reply #6 on: 23 January 2015, 09:10:07 »
There easy enough to do, about 15 minutes all in I would say.
If you are concerned then send the mechanism plus new optical pickup to me and I will change it (this is easy to remove and reduces size/weight for postage)
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #7 on: 23 January 2015, 12:56:42 »
Sounds like a good idea, I'll order the part and if I don't think I can do it I'll PM you.
Now as the CDC is not working either can I take one out off a known working 2006 head unit and put that in ( both are non Bose ) would it need any coding with Tech2  :-\
« Reply #8 on: 23 January 2015, 13:00:18 »
Easy to replace. No coding needed
http://www.omegaowners.com/forum/index.php?topic=90608.0
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #9 on: 23 January 2015, 13:16:53 »
Ok got all of that Rob, think I can do that. The 2006 I have is new so the CDC should last for a bit ;)
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #10 on: 29 January 2015, 13:47:26 »
Laser was in the post this morning, so a nice warm job inside this weekend :y
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #11 on: 09 February 2015, 12:08:34 »
Which never got to happen, head unit is stuck in car with disc holder not moving. So how do I get the disc holder out so I can remove head unit, can it be done.
« Reply #12 on: 09 February 2015, 12:52:42 »
If you mean the 4-disc cartridge is stuck, HU can be removed with it in situ
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #13 on: 09 February 2015, 16:59:37 »
Yep I know Rob, but if your remember I had snags getting the one out on the MV6 estate and you said put your hand in the disc holder with the cartridge out and with pins in pull the head unit out. I have the same snag on this one but the cartridge will not eject for me to get my hand in.
Page created in 0.028 seconds with 20 queries.
