Author Topic: P0100  (Read 2922 times)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
P0100
« on: 24 January 2015, 20:14:09 »
So this is a MAF related code i read on here and live data Can help to diagnose
Is it the MAF only live data i need to put up or the whole sheet cos there is a lot of it  :y
IE; Voltage and Kg/h
Steve B
  • Leicestershire
Re: P0100
« Reply #1 on: 25 January 2015, 00:13:21 »
MAF Not working proper   9 secs on tickover and when i increase rev MAF data stays same .
And the code is tripped up instantly after clearing code on start up
high MPG
Uneven tickover
« Last Edit: 25 January 2015, 00:20:38 by BIGtime »
Re: P0100
« Reply #2 on: 25 January 2015, 08:30:59 »
To be sure, does it run better with the MAF unplugged :-\
If yes, then you need a new one, if no, then there's potentially an air leak somewhere  :y
Re: P0100
« Reply #3 on: 25 January 2015, 18:41:12 »
Ah, another shitty code reader ;D
The fact its whacked at one end of the scale suggests the ECU isn't seeing the MAF reading at all. If should be able to detect that, and substitute a limp value.
Is the bugger plugged in?
Steve B
  • Leicestershire
Re: P0100
« Reply #4 on: 25 January 2015, 18:43:51 »
Yep  ;D ;D ;D
Is that what your thinking tb not plugged in  :-\
Re: P0100
« Reply #5 on: 25 January 2015, 18:52:22 »
Yep  ;D ;D ;D
Either not plugged in, completely 'dangle berries'ed, severely damaged loom or shagged ecu.
Steve B
  • Leicestershire
Re: P0100
« Reply #6 on: 25 January 2015, 18:53:59 »
Yep  ;D ;D ;D
Dont say that.. gonna nip out in bit have a look
Steve B
  • Leicestershire
Re: P0100
« Reply #7 on: 25 January 2015, 19:23:02 »
Yes its plugged in alright..Too dark to see how to unplug...What do you do press that little tab in on the side  :-\
Re: P0100
« Reply #8 on: 25 January 2015, 20:27:06 »
That's about it :y
Steve B
  • Leicestershire
Re: P0100
« Reply #9 on: 26 January 2015, 16:01:57 »
high MPG
Uneven tickover
Does that look any better   Coldish engine
« Last Edit: 26 January 2015, 16:03:30 by BIGtime »
Steve B
  • Leicestershire
Re: P0100
« Reply #10 on: 26 January 2015, 19:55:51 »
Drives a lot better now its not using the default settings in the ECU.. Put in a Known working MAF cleared codes been on a few trips and no more code and dash is clear for the first time...Great  :y :y
Re: P0100
« Reply #11 on: 27 January 2015, 18:42:59 »
That looks more viable for kg/hr. Shade high, but if the engine was cold...
Steve B
  • Leicestershire
Re: P0100
« Reply #12 on: 27 January 2015, 20:23:02 »
Yes its  sorted.. But to be on the double safe side. I bought Two MAF,s  ;D ;D ;D
Put the other one on today to give that a test too on a warm engine..
Re: P0100
« Reply #13 on: 28 January 2015, 18:01:13 »
That's about right.
