Author Topic: Mayo On The Oil Filler Cap & Coolant Low!!!!!!  (Read 2882 times)
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
« on: 29 January 2015, 19:23:56 »
As per heading, Coolant Low & Mayo on the Oil Filler Cap, what do we recon?? Oil Cooler?? 3.2 V6 02 Plate
Re: Mayo On The Oil Filler Cap & Coolant Low!!!!!!
« Reply #1 on: 29 January 2015, 19:24:28 »
Short journeys?
Jim
  • Glasgow
« Reply #2 on: 29 January 2015, 19:27:20 »
ish!!!!!!!!!!!
« Reply #3 on: 29 January 2015, 19:29:42 »
ish!!!!!!!!!!!
Doesn't sound like the oil cooler to me unless you have a load of brown sludge in the coolant.
Mayo is normal when the car is used mainly for short journeys.
Jim
  • Glasgow
« Reply #4 on: 29 January 2015, 19:32:59 »
Coolant bottle looks fine & nothing on the dip stick except oil, just wondering why its using coolant it the first time I've had to top it up for a while
« Reply #5 on: 29 January 2015, 20:12:18 »
Hbv or radiator drain plug are the two obvious choices...
Also check both thermoswitches on the passenger side end of the radiator and both the tops of the end tanks for evidence of coolant staining.
If that all checks out, then you're into pressure testing with the inlet manifold out to look for oil cooler plate/coolant bridge leaks :y
Another q... any smell of coolant in the cabin? Wetness under the drivers foot mat? Both could be the beginning of a heater matrix leak :-\
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #6 on: 29 January 2015, 21:19:22 »
As you've just noticed it.....
Top up coolant. Monitor amount of loss. Pressure test if this becomes a concern.
Mayo on filler cap.....short journeys and cold weather. Nowt to be concerned about.
RIP Paul Lovejoy
Jim
  • Glasgow
« Reply #7 on: 30 January 2015, 12:44:35 »
Thanks Guys, I'II keep an eye on the coolant level.
I was just surprised that the car needed coolant, the bottle only had about quarter in it, that's probably the first time I've had to add coolant for a long time so was just surprised it needed so much.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #8 on: 30 January 2015, 13:40:13 »
I had a leak which I could no detect until I ran the car and looked under the front of car and there was a tiny leak from the base of the radiator New rad and no more loss of coolant
« Reply #9 on: 30 January 2015, 14:14:55 »
Mine's been doing the same lately. The windscreen did develop a habit of fogging up immediately after a warm start, too, which made me dread that the heater matrix has gone. No sign of a leak, though, and I've since been running it with the air con off, and the windscreen doesn't fog up. I suspect hope the condensate isn't draining away for some reason, and the coolant leak is elsewhere.
