Author Topic: left side bagpipe coated in oil?  (Read 2204 times)
brian36
  • Milton Keynes
  • 2.6 mv6
« on: 06 February 2015, 10:48:06 »
hi just been out and noticed that left side bagpipe believe air intake from plenum coated in what looks like oil any ideas folks?
« Last Edit: 06 February 2015, 10:50:34 by brian36 »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: left side bagpipe coated in oil?
« Reply #1 on: 06 February 2015, 11:41:06 »
Left side as in Near Side?, first check for me would be Dip Stick / holder all ok, followed and Cam Covers, others wise is it oil? Power Steering fiuld?
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #2 on: 06 February 2015, 11:48:26 »
me getting mixed up right side then was left when facing anyway took off checked for split etc nothing apparent let run for a bit nothing else going to vx dealers so give it run and check when there thanks
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #3 on: 06 February 2015, 11:59:02 »
Best thing is to get the engine as clean of oil/muck as possible, then look again after a run, see if that shows anything up. Let us know how you get on. Strange the oil should be that far forward?
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #4 on: 06 February 2015, 12:05:06 »
I recently had an alternator fail and my bagpipes had a coating of what looked like oil but I dont think it was oil, something from the alternator burnt varnish? New alternator and no deposit on bagpipes.
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #5 on: 06 February 2015, 13:18:37 »
just took for run be it only 5 miles but dry, will keep a eye on in meantime thanks :y
« Reply #6 on: 06 February 2015, 14:55:21 »
Had exactly the same on our 2.6 - no signs of leakage on the bagpipe to plenum connector.  Changed it for another one - clean ever since.
