Author Topic: Coil pack  (Read 2793 times)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Coil pack
« on: 08 February 2015, 18:22:44 »
Is mine GM 9118115.. And is this the place to go  :-\  TIA
http://www.vauxhallworldparts.com/vauxhall.php?partnumber=9118115
powerslinky
Re: Coil pack
« Reply #1 on: 08 February 2015, 20:00:53 »
I'm pretty  sure  the 2-4-6 cylinder   coil pack is different to the 1-3-5   side . different part & no.
Is the 2-4-6 side the one that you want ?  as that is the part no. you have posted :-\
I brought a "genuine" Bosch 2.6 crank sensor from there  . . . & it failed in less than 6 months  :-\ :-\
Jamie  did warn me  that would happen ::) ::)
Their stuff seems very cheap for "genuine"
Steve B
  • Leicestershire
Re: Coil pack
« Reply #2 on: 08 February 2015, 20:05:51 »
Yes the 1,3,5 and 2,4,6 have different part numbers... and i want the 246 one which is that part number.. :y
powerslinky
Re: Coil pack
« Reply #3 on: 08 February 2015, 20:08:37 »
 :y :y
Steve B
  • Leicestershire
Re: Coil pack
« Reply #4 on: 08 February 2015, 20:16:02 »
Reply #2 made me look there . Works out at £77
http://www.omegaowners.com/forum/index.php?topic=76401.msg1027000#msg1027000
powerslinky
Re: Coil pack
« Reply #5 on: 08 February 2015, 20:21:38 »
Just read through that & Marks DTM recommended them . . . so must be ok IMO
My crank sensor may have just been a one off "rogue" one :-\ :-\
Re: Coil pack
« Reply #6 on: 08 February 2015, 20:34:44 »
Genuine Bosch from a motor factors is similar money :y
Steve B
  • Leicestershire
Re: Coil pack
« Reply #7 on: 08 February 2015, 20:37:57 »
Is that one in the link the proper one ie same as VX and not a pattern part junk. i see its bosch  :-\
steve6367
Re: Coil pack
« Reply #8 on: 08 February 2015, 21:00:41 »
I picked up a Bosch coil pack for the 2.2 from there over a year ago and been ok so far  :y
Steve B
  • Leicestershire
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
Re: Coil pack
« Reply #12 on: 08 February 2015, 21:29:18 »
Got my 2-4-6 from Vauxhallworldparts. Genuine Bosch, very quick delivery.  :y
