Author Topic: Front subframe bolts  (Read 1640 times)
ajsphead
  • North Somerset
    • Omega 2.2 DTi estate
« on: 13 February 2015, 16:56:01 »
Are these angle tightened for accuracy or because they are stretch bolts?
I have a little derusting job to do for which I need to loosen off the steering box and lower the o/s/r corner of the front subframe. I have tools to get into small spaces for derusting so I don't need to drop the components off completely.
Does anyone have a torque setting for the steering box bolts please?
Any tips for working in this area gratefully received.
« Last Edit: 13 February 2015, 16:58:52 by ajsphead »
Re: Front subframe bolts
« Reply #1 on: 13 February 2015, 17:07:21 »
Torque should be in Haynes :y
If you're only dropping one bolt...
ajsphead
  • North Somerset
« Reply #2 on: 13 February 2015, 17:24:57 »
Blindness now overcome. Have steering box bolt torque in Haynes.
Even though I only have to loosen the one bolt completely, I might have to back off the n/s/r and o/s/middle to get the corner I want to drop.
« Last Edit: 13 February 2015, 17:28:31 by ajsphead »
