Author Topic: NCDC2013/15 Bose Aux audio line in  (Read 9966 times)
Re: NCDC2013/15 Bose Aux audio line in
« Reply #15 on: 20 February 2015, 18:00:32 »
As a suggestion -
Use a Harmon Kardon Drive and Play unit - 1st generation units available for around £20 on the bay of e
Connect line out from Harmon unit to BOSE head unit via CD port as described
Throw iPod in the glovebox and forget about it
Far neater solution than messing with head units   8)
That would presumably require the acquisition of an iPod ::)
Nope. It has an aux in (as well as iPod connectivity. ) so you can fit a powered Bluetooth gizmo with 3.5 jack to the aux in. Although the dash mount display and controller are a bit pointless without a precious iPod it has to be said.
Hk needs to be hard wired to fm though, and radio reception will suffer. Although the hk works well.
« Reply #16 on: 20 February 2015, 18:10:11 »
Does the HK unit also do video?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #17 on: 20 February 2015, 19:15:19 »
No. Stick with your plan Al, far better quality wise doing it direct than using a FM Modulator and then using your FM Radio to demod it / recover the signal.  ;)
« Reply #18 on: 20 February 2015, 19:22:06 »
:y did that link make sense btw :-\
« Reply #19 on: 20 February 2015, 22:17:28 »
It's not that precious. ;D Audio only. :)
As said. Direct into the HU via cd slot or multi changer(?) is preferred imo. Either way, there's getting poxy unit in and out of that damn cage. PitArris's!
« Reply #20 on: 20 February 2015, 22:21:02 »
Of course, If you want video, you need hardware killers bit of circuit board :(
« Reply #21 on: 20 February 2015, 22:58:16 »
Have a perfectly useful 7" screen so not planning to upset the CID :y
zirk
  • Epping Forest
« Reply #22 on: 21 February 2015, 11:52:01 »
No, no link in the pm, do you want to send again.  ;)
zirk
  • Epping Forest
« Reply #23 on: 22 February 2015, 13:17:24 »
Whilst it does what it says on the tin, its a bit limited, as it relies on a proper RGB + Sync signal to work, kind of thing you could tap out of a scart plug a few years ago, most Video outputs / Camera / Portable / Mobiles etc tend to be simplified with HDMI or Composite Video (CVBS) these days.
« Reply #24 on: 22 February 2015, 14:13:07 »
Resent :y
    • 530D M Sport, 330i Coupe
« Reply #25 on: 22 February 2015, 15:09:08 »
Composite Video would be my requirement as the only useful thing I can see such a tiny screen being used for would be a reversing camera, even then it's a gimmick as you should be looking behind you!
