Author Topic: Thread lok for oil filter  (Read 5078 times)
powerslinky
« on: 15 February 2015, 17:40:52 »
Hi all ,
          want to change my "housing" type  paper element oil filter for the spin on type.
But I cannot seem to find where to get the TL 70  thread locking stuff.
Web search has found nothing  . . . can anyone advise where to get it from  or a similar product that will do the job ?
TIA     Al :y
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Thread lok for oil filter
« Reply #2 on: 15 February 2015, 18:14:34 »
If you don't mind me asking how much are  the necessary bits to do this conversion?
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #3 on: 15 February 2015, 18:46:20 »
Think I paid around £9 for the stub at agents and £1.50 for genuine filter off of the bay.  :-\ Oh and didn't bother with the lock thread stuff and not had a problem, just turn filter to around 3/4 turn after it touches the block
« Last Edit: 15 February 2015, 18:48:22 by kevinp58 »
powerslinky
« Reply #4 on: 15 February 2015, 18:52:57 »
http://www.selfadhesive.co.uk/adhesives/anaerobic-adhesives/scotch-weld-trade-threadlocker-tl70-50ml.html
Now why could I not find that Rob ::) ::) ::)   Thanks
Is this locking stuff really needed then ?    anyone else fitted this conversion without the thread lok ?
As ~i will probably never use it again  . . .seems a tad expensive for just one application ::) ::)
powerslinky
« Reply #5 on: 15 February 2015, 18:59:37 »
Kev . . .have you done a oil & filter change since you converted ?  if so   . . . I presume the filter came off ok & left the threaded stub in place ok :-\ :-\ :-\
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #6 on: 15 February 2015, 19:31:01 »
Yes 1 change and it stayed in place so far.  :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #7 on: 15 February 2015, 20:05:01 »
Just about any threadlock will do, although I would be using one of the milder versions. You should be able to find a small bottle for a few quid, and if you keep it in a sealed container it will last for years.
Don't forget to degrease both threads though, otherwise it won't work.
« Reply #8 on: 15 February 2015, 21:04:24 »
I still think you're fixing a fault that doesn't exist  :-\
powerslinky
« Reply #9 on: 16 February 2015, 14:40:25 »
not sure what you mean by that Andy ?  :-\ :-\
 could you enlighten ?   :y
« Reply #10 on: 16 February 2015, 14:45:26 »
It was a cryptic way of saying ..... the paper filter in the ally housing works - why change it for a spin on filter? If it ain't broke .... don't fix it.  :y
Various people saying they're modifying for the better by fitting the spin on filter, I never had any problems in 10 yrs of of Omega ownership in removing the ally housing and the oil was changed at least every year or better  ;)
powerslinky
« Reply #11 on: 16 February 2015, 14:55:26 »
Ah  . . . see  now  ;)     I found filter change much easier on the one  2.5 I've  had with a spin on .
The present 3.2 alloy housing & paper element  is all ok  . . . no problem getting off last time & torqued up correctly when refitting . . . so should be ok for all future oil changes.  May just leave it then  :y
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #12 on: 16 February 2015, 15:16:26 »
Ok, I'm biased, I've never used the later paper jobbie, but just ignoring that a VOF93 costs £1 on tradeclub, I suppose the idea that the older type is superior probably comes from those times/people that have literally had to smash the old one off. Given that you do that, then have to blag a lift from a mate to go to the Stealer for a replacement housing (no idea what they are, but I imagine not pence) then fit the new housing, does seem a backward stem when compared with the 'destroy the old filter when removing, simply plop the new on on hand-tight, have a cuppa' method.
I suppose if you do your own servicing and the housing comes off fine the first time you change the oil, and torque it up properly, there's no reason to suppose that it won't come undone again for the next ten years. Perhaps the idea (or myth?) that the earlier VOF 93 is the superior is from previous owners/garages tightening it too far, thus making removal without destruction impossible.
Does anyone have experience of personally tightening their later-type up one year, then come next oilchange it's stuffed?
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #13 on: 16 February 2015, 20:24:35 »
I changed mine because when I got my 3.2 some gorilla had done it up and It took a long bar to get the cover off then when it eventually did come apart the web inside was all broken so I put the old canister type on as the housing would have cost an arm and a leg from a dealer to replace.  :y
BazaJT
« Reply #14 on: 16 February 2015, 21:39:33 »
For me it's a matter of personal preference really.I think in going from a spin on type to the element type was a retrograde step on GMs part.Then factor in that quite a few people have had bother removing the element housing-for whatever reason-and that the spin on is cheaper than the element one so after a few oil changes you're in profit from the tenner or so it costs to convert,I think I'll be going this route come next oil/filter/breather clean time.
