Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 ... 24   Go Down
Author Topic: Engine Loom  (Read 84687 times)
Re: Engine Loom
« Reply #105 on: 16 March 2015, 23:19:55 »
To be in the cylinder, it has to be either from summat always present... valves, pistons or plugs, or summat induced, ie in via the inlet tracts...
Anything else such as timing gear would remain on top of the head... so any cam or lifter damage would be due to debris fouling the exhaust valves on the way out. Be interesting to see what they look like :-\
Re: Engine Loom
« Reply #106 on: 16 March 2015, 23:21:23 »
Ref the piston Kevin - I thought that too, however spinning the crank slowly, they all appear to look like that, as they come up from the bottom..
A bit of oil also went into the holes before the next compression test, which didn't affect results..
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: Engine Loom
« Reply #107 on: 16 March 2015, 23:36:45 »
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: Engine Loom
« Reply #108 on: 17 March 2015, 08:47:03 »
This reminds me of the damage evident in Mick Dundees 2.6 engine a few years back. Only more severe. There was a suggestion his  car had been through flooded roads during a trip to Newent. Bad enough for the engine to "possibly" ingest water.
But why does it always seem to be the 2,4,6 head?
Post 177
http://oldsite.omegaowners.com//forum/YaBB.pl?num=1236287115/all
Re: Engine Loom
« Reply #109 on: 17 March 2015, 08:58:00 »
Are those the inlet or exhaust cam bearing caps?
As for it always being the 246 side, arguably the intake is nearer the air supply being on the righthand side of the engine :-\ Or perhaps a temperature issue... that side of the engine is relatively crowded :-\
chrisgixer
  • Woking ham
  • Banned
Re: Engine Loom
« Reply #110 on: 17 March 2015, 09:29:40 »
What's in the back of my mind, is the fuel trims when fiddling with LPG. They don't go both lean, or both rich. 1 bank goes rich, Tother lean. I forget which though, and I've never seen them go out on petrol to see if it's normal on petrol, or something is arse backwards on LPG. ...or it's simply that plus/minus is allocated wrong (on the software  :-X)
chrisgixer
  • Woking ham
  • Banned
Re: Engine Loom
« Reply #111 on: 17 March 2015, 09:33:01 »
So, if the maf is failing, would one bank go lean (246) and tother rich...? (As I've seen with mine on gas and the software that won't ge named)
« Last Edit: 17 March 2015, 09:35:16 by chrisgixer »
Re: Engine Loom
« Reply #112 on: 17 March 2015, 10:45:25 »
Nope
Steve B
  • Leicestershire
Re: Engine Loom
« Reply #113 on: 17 March 2015, 10:50:47 »
Both... They are all like it  :y
They all look like they have had sandpaper around them
Re: Engine Loom
« Reply #114 on: 17 March 2015, 10:52:11 »
Those cam caps have been fitted in the wrong place/orientation in the past I would infer by looking at the wear.
But clearly they are not contributing to the issues.
Do a valve leak down test to check where the compression loss is before doing anything.
Re: Engine Loom
« Reply #115 on: 17 March 2015, 10:56:47 »
Bit late for that if James has already pulled the head off, no?
Re: Engine Loom
« Reply #116 on: 17 March 2015, 10:58:29 »
Er no, fit plugs, turn head over and fill combustion chambers with a suitable fluid (not water).  :y
Re: Engine Loom
« Reply #117 on: 17 March 2015, 11:14:09 »
No this test requires head off :y
Really struggling to get a head gasket for tonorrow, I have all the other parts on the side!
Annoyingly I have y26se head gaskets and x30xe composite ones but no bloody metal y32se ones!
Re: Engine Loom
« Reply #118 on: 17 March 2015, 13:27:31 »
Have had the head flat, upside down, for about an hour.
Plugs in, each well full of white spirit
Number six has dropped notably. Guessing 2mm.
Number four has dropped a tiny bit. Still detectable by eye
Same for number two
Consistent with the compression test...
Re: Engine Loom
« Reply #119 on: 17 March 2015, 13:32:22 »
No its not.....that's a bit more concerning as such a small amount of loss would not result in such a big compression loss.
Which port is it running into?
Exhaust or Inlet.
Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 ... 24   Go Up
