Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 ... 24   Go Down
Author Topic: Engine Loom  (Read 84693 times)
Re: Engine Loom
« Reply #120 on: 17 March 2015, 13:44:10 »
Appears to be the inlet port, if I wipe my finger in there it's wet with white spirit, whereas exhaust port looks dry
In fact I may have mis judged, pot 6 is now half emptied between now and my previous post...
Re: Engine Loom
« Reply #121 on: 17 March 2015, 13:48:03 »
That would be consistent with the first picture in the thread I linked to... although compression was only a touch down :-\
Re: Engine Loom
« Reply #122 on: 17 March 2015, 13:49:11 »
That's still nothing, on Brians car, which had a lump missing out of the exhaust valve, the compression ratio achieved was similar but the fluid ran out in seconds......  :y
Re: Engine Loom
« Reply #123 on: 17 March 2015, 13:49:56 »
Shall I start removing valves? :y
Re: Engine Loom
« Reply #124 on: 17 March 2015, 13:50:36 »
Re: Engine Loom
« Reply #125 on: 17 March 2015, 13:54:10 »
On that cylinder its worth doing so, check if the guides are tight.  :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: Engine Loom
« Reply #126 on: 17 March 2015, 14:00:51 »
The valves that took the least were the two inlets on pot 2
Re: Engine Loom
« Reply #127 on: 17 March 2015, 14:04:30 »
Ok just making a cuppa and I will go and dust off the spring compressor :D
I've just spent the last hour removing a proven good head from my 3.2 project, we are looking to refit this / retest tomorrow :y
Re: Engine Loom
« Reply #128 on: 17 March 2015, 14:06:32 »
I accept it may be the pictures/angle, but I'm still not convinced those pistons look true in the bores.......
I will have a look at the one I just stripped for comparison...
Re: Engine Loom
« Reply #129 on: 17 March 2015, 14:18:21 »
I also say the damage to the piston crowns and heads is too excessive to be a plug electrode
I also don't buy that it's happened to all three cylinders...
Given it was ok before it was worked on, some sudden event has caused this loss of compression.
But what? :(
Re: Engine Loom
« Reply #130 on: 17 March 2015, 14:21:31 »
Its not, that is pretty typical plug electrode damage......but how come those pistons are not pocketed.....is there an R number on the block code?
Re: Engine Loom
« Reply #131 on: 17 March 2015, 14:24:20 »
Maybe the Y32SE ones are not pocketed, the Y26SE ones are.....
Re: Engine Loom
« Reply #132 on: 17 March 2015, 14:56:22 »
Re: Engine Loom
« Reply #133 on: 17 March 2015, 14:57:37 »
This is the no6 inlet valve from the port where most of the damage was...
Re: Engine Loom
« Reply #134 on: 17 March 2015, 15:02:02 »
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 ... 24   Go Up
