Pages: 1 ... 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 ... 24   Go Down
Author Topic: Engine Loom  (Read 84690 times)
Re: Engine Loom
« Reply #165 on: 17 March 2015, 21:21:13 »
They are all perfect
Hmmm, this is my convinced face...
Re: Engine Loom
« Reply #166 on: 17 March 2015, 21:23:57 »
Lol!!!
Sadly to me, investigating as an outsider, the old plugs are an unknown to me
But if daz / Steve think they were ok, I've no reason to disbelieve :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: Engine Loom
« Reply #167 on: 17 March 2015, 21:26:55 »
james i cannot explain the knocking straight the way on start up...
 But this is one thought.....before i had belt/stat ETC done i never ever seen any 300 codes..now i see them all the time once the engine gets up to temp...Well lets face it. car never got up to full temp with stat wide open and how cold it was a few weeks ago.but now it gets up to temp ..And thats when codes come .. Just a thought
Re: Engine Loom
« Reply #168 on: 17 March 2015, 21:30:55 »
Mine was the same... the second the fans kicked in, 0300, 0306...
Steve B
  • Leicestershire
Re: Engine Loom
« Reply #169 on: 17 March 2015, 21:35:32 »
When the belt ETC was done.. i turned the key for the first time and it was Knocking like hell...We then instantly ended up in my boot going through all the waste to have a second look at the old plugs,To make sure no electrode had fell off (i remember that part very well) All old plugs were good
Re: Engine Loom
« Reply #170 on: 17 March 2015, 21:37:13 »
We may never know...
But we need to sort out the compression issue before even contemplating looking at anything else.... Else we will just chase our tail :y
Re: Engine Loom
« Reply #171 on: 17 March 2015, 21:41:33 »
This is my worry and why I'm worried a foreign object was introduced at this stage.
Why would it be fine before and then knock so much after the work, to the point it has to be stripped to Check it all again?
If the engine had been turned loads and loads the lifters might be depleted of oil, but I sill wouldn't expect the noise to be of such concern that it warrant a further strip down...
Re: Engine Loom
« Reply #172 on: 17 March 2015, 21:53:34 »
Anything bigger than an electrode would have been much more devastating... and I suspect the damage is only as it is because it happened at idle... higher revs under load and the debris would have been cleared out by the combustion process...
Anything smaller simply wouldn't damage anything...
Steve B
  • Leicestershire
Re: Engine Loom
« Reply #173 on: 17 March 2015, 21:54:47 »
It deffo warranted a further strip down..It sounded bad..Like a lifter.....Timing Belt was rechecked..Aux belt was then removed to be sure  water pump was ok. then finally Cam covers were off again to make sure no foreign object had been introduced to engine.Plugs were also out again to check
Nothing was found....
« Last Edit: 17 March 2015, 21:56:48 by BIGtime »
Re: Engine Loom
« Reply #174 on: 17 March 2015, 21:56:50 »
We might never know.
The important thing is. Will a good head fix the compression issue
I guess tomorrow will tell!
Re: Engine Loom
« Reply #175 on: 17 March 2015, 21:58:53 »
Could the rough valves be reground in the seat and the head refitted?
Re: Engine Loom
« Reply #176 on: 17 March 2015, 22:00:10 »
Possibly
But in the circs, I'd rather fit a known good head so there is no question :y
Steve B
  • Leicestershire
Re: Engine Loom
« Reply #177 on: 17 March 2015, 22:02:07 »
Possibly
Cos you have piston rings thoughts in your head dont you  :-\
Re: Engine Loom
« Reply #178 on: 17 March 2015, 22:05:01 »
Possibly
I still think valves are much more likely....
But if fitting a known good head still results in low compression - what else?
Re: Engine Loom
« Reply #179 on: 17 March 2015, 22:05:25 »
Possibly
There would be significant scoring of the bores if the fire rings had escaped... rather than simple machine marks :-\
Pages: 1 ... 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 ... 24   Go Up
