Pages: 1 ... 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24   Go Down
Author Topic: Engine Loom  (Read 84636 times)
Re: Engine Loom
« Reply #225 on: 19 March 2015, 15:13:49 »
From stone cold, through until it's warmed up, at idle rpm :y
Ok james ...live data gives you about 3 readings per second.... Thats a lot of data to put up  ;D ;D ;D
Just do as much as you reasonably can from cold...
I'm thinking tomorrow or Monday for another look :y
Re: Engine Loom
« Reply #226 on: 19 March 2015, 17:12:10 »
Just upload a CSV / Excel file somewhere with all the readings in.. assuming you're using the reader that shall remain nameless.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: Engine Loom
« Reply #227 on: 19 March 2015, 17:37:30 »
Yep your correct.. Which reading do you want up owing to there being a lot of them and screen shot will be very very wide
Re: Engine Loom
« Reply #228 on: 19 March 2015, 17:41:29 »
Fuel injector durations. I must be honest, I don't remember if I checked these :(
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Engine Loom
« Reply #229 on: 19 March 2015, 18:57:59 »
If it's any use I should have a 2.6 throttle body and fuel rail gubbins in the shed that can be in the post tomorrow if it's any use, postage cost only !
Steve B
  • Leicestershire
Re: Engine Loom
« Reply #230 on: 19 March 2015, 19:18:28 »
Thanks very much for kind offer  :y
Re: Engine Loom
« Reply #231 on: 19 March 2015, 19:19:14 »
I have spares here for testing purposes but, if I end up giving them to Steve, can I take you up on that please, as I will need them for my project :y
Steve B
  • Leicestershire
Re: Engine Loom
« Reply #232 on: 19 March 2015, 19:27:13 »
Right here we go this is from start with codes cleared until dash light starts flashing 120 mins
Knock sensor is always inactive and voltage is Nil on both banks
P0161 O2 Sensor Heater Circuit Open (Bank 2 Sensor 2)  is there instantly..then the codes for the 1,3,5, cylinders..
This is the best way i could get all this info on screen  :-[
  • Auckland
    • Mazda MPV
Re: Engine Loom
« Reply #233 on: 19 March 2015, 19:38:03 »
So it purrs at 2000 rpm but 1/3/5 misfire dreadfully at idle?
1/3/5 are the same side as the vacuum connection for the brake servo - is there an uncontrolled air leak ? (nut loose / pipe cracked / servo faulty)
If there is air entering through the vacuum connection then the ECU would close the throttles to control the idle speed which would make 2/4/6 run rich and 1/3/5 run lean (until it tried to run closed loop using the lambdas))
Steve B
  • Leicestershire
Re: Engine Loom
« Reply #234 on: 19 March 2015, 19:41:42 »
That pipe from servo goes in the other side with the 19mm/17mm nuts  :-\ :-\
  • Auckland
    • Mazda MPV
Re: Engine Loom
« Reply #235 on: 19 March 2015, 19:47:54 »
OK - I may have got my banks muddled  :-[ so 1/3/5 will run rich and 2/4/6 run lean. Either way the drivers side will get starved of air and the passenger side will get unmetered air via the vacuum hose. (if that is the problem)
Re: Engine Loom
« Reply #236 on: 19 March 2015, 19:59:26 »
Yup :y with it missing you might not hear the leak :-\
Steve B
  • Leicestershire
Re: Engine Loom
« Reply #237 on: 19 March 2015, 20:07:25 »
And you would have a rock hard brake pedal..  :y
Re: Engine Loom
« Reply #238 on: 19 March 2015, 20:12:46 »
Don't bank on it... With the engine running and that pipe vaguely attached, the air pressure in the servo will be lower than atmosphere so partial vacuum will offer some assistance :y
Steve B
  • Leicestershire
Re: Engine Loom
« Reply #239 on: 19 March 2015, 20:48:08 »
Deffo gonna have a look around at that area to see if a small split or something... It was dark when we finished ..its got to be something minor like that i think  :y
Pages: 1 ... 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24   Go Up
