Author Topic: Ignition Coil pack  (Read 1661 times)
Rifai
  • UAE
    • Omega B 1997
Ignition Coil pack
« on: 21 February 2015, 13:45:18 »
Hello,
I am driving Omega 2.5 V6 / X25XE / 1997
Plug No.1 stopped working. When I went to workshop they told me the problem was with the coil pack.
My mechanic has changed 3 coil packs so far but it didn't work. he plugs the coil and test the pins one by one outside to make sure spark is coming and all good. after fitting on the engine spark no.1 stops
even if he tries it again without plugining the sparks no.1 still no sending any spark.
any idea why this is happening? he even changed the ecu just to try but same issue.
my problem started like 1 month ago when the car started to stall and go completely off when I stop or engine is on idle.
Would it be something else that is faulty other than the coil?
appreciate your comments
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
Re: Ignition Coil pack
« Reply #1 on: 21 February 2015, 13:55:16 »
Have you tried another set of plug leads?
sjc
  • Alloa, Scotland
« Reply #2 on: 21 February 2015, 13:57:28 »
Could also be a wiring loom issue but for that I'd suspect you'd see 2 cylinders down since the coil is a wasted spark setup.
Rifai
  • UAE
    • Omega B 1997
« Reply #3 on: 21 February 2015, 14:14:39 »
the wiring are Ok according to the guy. on my old coil 1 cylinder is down after fitting the new one 2 are down now so i fitted back mine.
how can you check is the plug wires are ok or not?
sjc
  • Alloa, Scotland
« Reply #4 on: 21 February 2015, 15:29:50 »
You can check them with a multi-meter - you should see a pretty high resistance, about 10k I think, but if any are open circuit then they are broken.
