Author Topic: Just conformation realy.  (Read 3267 times)
moggy
  • hartlepool
    • vauxhall omega 3.0 elite
« on: 21 February 2015, 21:58:29 »
Hi everyone,i think i have a heater matrix problem.Drove to Birmingham last night, set the two switches to the right full red.And the blower to 2 lovely hot air. After two hours it started to get a bit cold,put my hand over the vent.Only Luke warm,and when we stopped at the service at idle it was cold.No coolant loss engine temp 92,so suggest the matrix is oppsed.(Great title for a film) ;D ;D.Any advice welcome Dean. :y
Re: Just conformation realy.
« Reply #1 on: 21 February 2015, 22:10:43 »
Have a rummage through the guides... Heater only working one side... Applies equally to both sides, but quite a coincidence if both at same time...
Other thing is to check hbv function. Applying or removing vacuum should make a difference in the cabin. Climate panel reset might also be in order. :y
moggy
  • hartlepool
« Reply #2 on: 21 February 2015, 22:37:39 »
Hi AL cant do the reset as its just knobs.(excuse the pun)Yes heat down on both sides.
« Reply #3 on: 21 February 2015, 22:47:27 »
Is yours an early one then?
moggy
  • hartlepool
« Reply #4 on: 22 February 2015, 12:37:59 »
Yes AL any ideas.
moggy
  • hartlepool
« Reply #5 on: 22 February 2015, 13:36:58 »
Is there some kind of reset,for the older cars.Dean
moggy
  • hartlepool
« Reply #6 on: 22 February 2015, 13:50:44 »
BTW had my coolant replaced recently,could this be related. :y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #7 on: 22 February 2015, 14:14:28 »
After a coolant change there coud be an airlock somewhere.
« Reply #8 on: 22 February 2015, 14:21:38 »
From cold...
Coolant cap off.
Top up coolant.
Ignition on.
Heater controls both to Hot.
Engine on.
Allow to idle until fan kicks in/10 mins.
Top up as required.
Refit cap.
Allow to cool overnight.
Restart and hold onto the top hose.
If this gradually warms up Stat is getting lazy, if it suddenly gets hot after five mins or so, the stat fine...
Not much else to go wrong without ecc :y
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #9 on: 22 February 2015, 14:36:59 »
Hmmm... early heater controls used vacuum to move the control flaps, etc.  Entirely possible that the diaphragms may have deteriorated with age.
Do you get any funny noises from behind the dash when the engine would be giving lots of vacuum, like when decelerating?
moggy
  • hartlepool
« Reply #10 on: 23 February 2015, 21:50:40 »
Hi mate no noises,but funny you should mention vacuum to move the control flaps.As when i turn the knobs to face feet etc the air only comes out of the,side and window vents. ??? :-\.Dean :y
moggy
  • hartlepool
« Reply #11 on: 24 February 2015, 17:31:00 »
From cold...
Coolant cap off.
Top up coolant.
Ignition on.
Engine on.
Top up as required.
Refit cap.
Thanks Al i will do this first,then change stat if needed.Then change hbv,flush matrix and rad.Think i will ask my mechanic to do this,as i an not to confident with spanner twirling. ;D :y
moggy
  • hartlepool
« Reply #12 on: 09 March 2015, 17:37:15 »
From cold...
Coolant cap off.
Top up coolant.
Ignition on.
Engine on.
Top up as required.
Refit cap.
Hi all well looks like,lazy stat.Would any kind oofer like to help me,change the stat change hbv and flush matrix.As my mechanic is very busy at the moment,and would like to get it done asap. :) :y Dean.
