Author Topic: Indicators Stopped Working  (Read 3364 times)
flymofred
  • nr. Tunbridge Wells (Royal)
    • (53) 2.6 Elite Estate
« on: 25 February 2015, 20:30:45 »
Can any one tell where the indicator  relay is. They have been flashing a few times then gave up , now they have stoped altogether the hazard lights have also now stopped working is there a diagram of the whole board for future reference. Thanks martinH
Re: Indicators Stopped Working
« Reply #1 on: 25 February 2015, 20:32:18 »
Start with the hazard light switch... press it on and off rapidly about twenty times and report back :y
« Reply #2 on: 25 February 2015, 20:53:09 »
Can any one tell where the indicator  relay is.  ......
under the steering column ..... tallest relay there IIRC
flymofred
« Reply #3 on: 25 February 2015, 20:59:19 »
 After pressing Haz. 20 ish times With ignition off nothing. With ignition on hazards flashed twice then nothing, indicators nothing as well .  ta
« Reply #4 on: 25 February 2015, 21:10:02 »
Relay it is then... which one though...
Do the indicators flash when you lock/unlock with the remote :-\
flymofred
« Reply #5 on: 25 February 2015, 21:29:38 »
Yarp
« Reply #6 on: 25 February 2015, 21:35:26 »
Yarp
Ok, that rules out the relay up behind the glove box, so leaves the one under the steering column...
As Andy suggested, it's the tall one... ignition on, and indicator to the right/left (either or), then give the relay a flick :y
Whilst you're at it you might as well check the fuses...
flymofred
« Reply #7 on: 25 February 2015, 22:04:41 »
Okey dokey wil be out there tomorrow. And check the identified relay Thanks for the help much appreciated martinH
flymofred
« Reply #8 on: 26 February 2015, 15:01:44 »
Once again my problem is solved by members of this forum Ie failed relay, and where it is in the car. It's nice to be a flasher again. Thanks martinH
« Reply #9 on: 26 February 2015, 18:05:40 »
Ooh er, you Kentish folk are rather forward in your ways... :o ;D
Glad it's sorted :y
Page created in 0.301 seconds with 20 queries.
