Pages: 1 [2] 3  All   Go Down
Author Topic: Front tyres issue  (Read 16503 times)
unlucky alf
  • worksop, notts
Re: Front tyres issue
« Reply #15 on: 27 February 2015, 18:31:45 »
UPDATE,,,,I made up the Mark special tool today & found that although my N/S is pretty much spot on the O/S is a mile out, :o, Before i go wading in with the spanners is there anything i should check first that might have caused this?, & secondly if only one side is out would it still cause both front tyres to get chewed on the inside edge?.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #16 on: 27 February 2015, 19:17:06 »
As the Omega has about 5 degrees of adjustment, from positive through to far too much negative, why would you bother with eccentric bolts?
« Reply #17 on: 28 February 2015, 00:43:58 »
There have been one or two mentions of some set up company or other, in the land of dodgy water , that allegedly couldn't achieve the correct camber setting due to lack of adjustment in the shock to knuckle mounting points. In other words the holes in the shock whereby "ovalised" enough. In that instance, if even remotely true and not a poor excuse by the operator, camber bolts could have a use.
But otherwise, none whatsoever. ...I wonder if Monaro shocks (on Elvins car iiirc) don't have the camber adjustment the omega has. Perhaps?
« Reply #18 on: 28 February 2015, 00:52:57 »
Alf Darling. Listen very carefully. CHECK THE GUIDES SECTION! It's aaaaslll there. :-*
« Reply #19 on: 28 February 2015, 00:55:34 »
Monaro adjustment machined into the steering knuckle :y
« Reply #20 on: 28 February 2015, 01:00:40 »
Aha! That's why we needs camber bolts.
Genuine omega shocks don't need them though. Unless you use a set up company in Northamptonshire, going by posts here. :-\ (most odd)
« Reply #21 on: 28 February 2015, 01:06:39 »
After thought..,,
Or is omega the same....? (As Monaro with oval knuckle holes....?) I really can't remember.
Anyway. You get the theory with camber bolts presumably?
« Reply #22 on: 28 February 2015, 01:25:37 »
After thought..,,
Thems sameses :y
« Reply #23 on: 28 February 2015, 01:27:56 »
After thought..,,
Thems sameses :y
Ok. So do they act as an eccentric allowing diy adjustment of camber by turning the bolt maybe?
« Reply #24 on: 28 February 2015, 02:10:33 »
Lower bolt is fixed pivot, upper bolt hole is about 1.5 times bolt diameter and can be extended a fraction with a round file as required :y
As Nick suggests, there should be adequate scope for,adjusting all but the most banana shaped cars :y
elvin315
  • Catskill, New York, USA
  • Catera...Cadillac's unloved stepchild.
« Reply #25 on: 01 March 2015, 00:25:04 »
For the record my Catera has Koni Sport inserts in the original strut bodies so the upper and lower knuckle holes are exactly how they would be on a stock Omega. She also has Powerflex front/horizontal bushes and new tie-rod ends. I didn't install the eccentric bolts myself so I can only attest to the results I've experienced. I don't have exact mileage numbers but the tires have lasted longer and worn more evenly after the bolts than before them. The wear is still based to the inner part of the tread but that's just the nature of our suspension.
« Last Edit: 01 March 2015, 00:33:04 by elvin315 »
Is that all there is, is that all there is
If that's all there is my friends, then let's keep dancing
Let's break out the booze and have a ball, If that's all there is
« Reply #26 on: 01 March 2015, 01:08:49 »
Yes the state of the wear is due to the suspensions camber setting. The wear should be focused towards the inner edge by the time the tyre is spent ( we have a 3mm tread wear limit on the centre two thirds iirc ) but driving style affects the wear so more aggressive drivers need more camber to achieve this. Apologies if I'm quoting the rule book at you though I'm sure you know all this.
Point is the tyre wear is not to do with the bolts. The original components do not need them, or at least not to enable a setting that is otherwise out of reach, anyway.
I've not used them, as not needed, so can't dismiss them completely but, for instance, Smeagols car runs 30mm drop front suspension, stock boots, yet there is still excess camber available.
When the car came to me it was running an inch higher than stock too. Same bolts achieved the required setting.
What might be handy is the ability to turn the camber bolt with the eccentric section within moving the top of the hub in and out as required, in order to adjust the actual camber setting during set up. Although I guess the bolt length would need to be more cranked than excentric.  But other than that....
...No need. :)
Apologies re the Monaro shocks guess. Must of been another thread I saw.
« Reply #27 on: 01 March 2015, 02:50:09 »
I believe Elvin has Pedders GTO springs, so presumably same as Monaro :-\
EMD
  • Noofhampton
    • 95t
« Reply #28 on: 01 March 2015, 18:44:19 »
Is that mr.gixer  ::) ::) ::)
Omegatitis
elvin315
« Reply #29 on: 01 March 2015, 22:15:46 »
Not Pedders, stock GTO/Monaro springs. They lower our cars an inch (25.4mm).
Pages: 1 [2] 3  All   Go Up
