Cambelt or Camchain. Which is best?
Started by Field Marshal Dr. Opti, 28 February 2015, 12:50:49
Seen a jag (the shite Mondeo one) v6 engine in for cam chain failure. Hideously complex chain routing. 3 differant chains iirc. Plastic chain guides. Worn chains resulting in stretch and poor running. Then ultimately chain failure where the U link had worn through. Clearly a softer link than the rest of the chain.
Iirc it had done 60k.
Bill? It was up over 1k and counting at the time.
Belts don't wear and stretch, but do perish and let the cords escape . But not until more than double the service life of the tensioner on omegas.
Interference engines are a result of higher compression to give better performance.
Belt every time for me, unless it's a stupidly simple arrangement such as on a pushrod engine. You're going to have to accept a shedload of slop in the timing then, anyway. ;D
Yes, you have to maintain a belt, but that's a non-issue for me, even with the relatively short interval on the Omega, and at least you can get to it.
Quote from: Kevin Wood on 03 March 2015, 10:12:13
VW v6/v8/v10 anyone...  ;D
henryd
Quote from: Taxi Al on 03 March 2015, 16:16:41
My Vw 5 banger is gear driven,actually so are water pump,a/c ,alternator and pas pumps,we don't need that lot going wrong :-X
other rides
78bex
#36
So why not run the cam drive belt into the sump oil for more efficency  :o
https://www.youtube.com/watch?v=IFj5UIZx2cE
chrisgixer
Nah. Makes access more tricky. Like the Ford give crap about that.
Quote from: henryd on 03 March 2015, 18:26:38
My Vw 5 banger is gear driven, actually so are water pump, a/c ,alternator and pas pumps, we don't need that lot going wrong :-X
Gear driven....chatter chatter chatter.....or if they have the spring loaded compensator gear set nice and quiet......until they age and then chatter chatter chatter  ;D
henryd
Quote from: Marks DTM Calib on 04 March 2015, 13:35:48
Yes,a little at cold idle but very quiet once revving(for an oiler) ::)
other rides
