Author Topic: Omega B (2002) CID issue  (Read 2677 times)
road rage
  • Norwich UK
    • omega b
« on: 02 March 2015, 06:57:14 »
Need help in solving the problem I have with my CID I brought a spear CID incase the original one goes wrong the one I got as a spear was unpaired from doner car made sure that it had the same part number and ident code as the original one that was fitted to the car every thing works how it should but for some reason it says
Attention brake lamp fuse
Brake lamp fuse is ok not blown and all 3 brake lights work have put my tech 2 on the car and gone into the data list for the CID and it's saying there's a brake lamp fuse fault.
With the msg I get I don't get the brake light check when you turn the ignition on just brake lamp fuse and every 15 mins.
I put the original CID back in and problem gone also checked the part numbers in tech 2 on both CIDs and they are the same
What could be causing this issue I have no idea where to look??
« Last Edit: 02 March 2015, 07:06:20 by road rage »
Re: Omega B (2002) CID issue
« Reply #1 on: 02 March 2015, 17:52:04 »
Is the code index on the CID correct. If yes, its probably toast
road rage
  • Norwich UK
    • omega b
« Reply #2 on: 02 March 2015, 19:36:09 »
Yes set the code the same as the orignal one how would it got toasted??
« Reply #3 on: 03 March 2015, 08:13:32 »
Code index, not ident code
road rage
  • Norwich UK
    • omega b
« Reply #4 on: 03 March 2015, 09:16:11 »
Just plugged tech 2 in this morning and found a DCT in the CID this is what it's saying
33 Add on heater circuit high input
This car don't even have a add on heater so this is strange
« Reply #5 on: 03 March 2015, 17:20:08 »
Which is why I think code index is wrong. What is the code index on it?
Page created in 0.029 seconds with 20 queries.
