Author Topic: Cam Belt tensioner  (Read 1706 times)
Arryace
    • 2.0 16v Auto
Cam Belt tensioner
« on: 02 March 2015, 16:03:44 »
Hi.
I have tried to search for the answer but cannot find it.
I have fitted a new cam belt to my 2.0 16v but have found when adjusting the tension the indicator doesn't move to point to 'new belt'
If I keep turning the Allen key it goes past the tights point and back to slack again.
Any thoughts?
« Last Edit: 02 March 2015, 16:10:32 by Arryace »
Re: Cam Belt tensioner
« Reply #1 on: 02 March 2015, 16:12:33 »
Simples, you have the water pump fitted incorrectly, its pulley is offset and hence alters the belt length.
4x4
« Reply #2 on: 02 March 2015, 22:56:50 »
There is a notch on the water pump that should be set at the 11 o clock position
Arryace
    • 2.0 16v Auto
« Reply #3 on: 05 March 2015, 20:42:31 »
Thanks this has cured the problem now just to set the timing up  :y
