Pages: 1 [2] 3  All   Go Down
Author Topic: Air tools - 5th March ...  (Read 10590 times)
Re: Air tools - 5th March ...
« Reply #15 on: 03 March 2015, 10:17:01 »
Only thing I wouldn't bother with is the filter lubricator. Mine was all or nothing as far as the oil dosage was concerned, then, as I was adjusting it, the thread stripped on the oil adjuster and it blasted me with a fine spray of oil at 8 BAR until the reservoir was empty. >:(
 ;D ;D ;D ;D ;D ;D Sorry Kevin, but that raised a much needed smile!
My Aldi/Lidl lubricator had a hair trigger - oil dosage was either zero or everything-in-30-seconds and nothing in between.  I do have a much, much nicer Norgren supplied one which ... the plastic fill screw sheared off of the first time I tried to undo it. >:(
Mrs. KW consumes vast quantities of expensive shampoo (about 1/4 of a bottle a time :o ) so I make a point of buying the cheapest 47p a bottle shampoo and making the bottle last a year or more. ;D Not that day, sadly.  ::) Think I ended up doing a prewash of swarfega too. >:(
« Reply #16 on: 03 March 2015, 11:57:53 »
I know that one all to well, 'do you take two bottles of shampoo into the shower'......yes bloody fairy liquid and Swarfega!
« Reply #17 on: 03 March 2015, 12:00:25 »
 ;D ;D ;D
« Reply #18 on: 03 March 2015, 12:06:17 »
Brake cleaner is particularly effective at degreasing.. ;D
EMD
  • Noofhampton
    • 95t
« Reply #19 on: 03 March 2015, 15:23:28 »
We all agree this is a good buy then  :-\
Omegatitis
« Reply #20 on: 03 March 2015, 15:53:09 »
Yes, but give the oiler a miss. :y
EMD
  • Noofhampton
    • 95t
« Reply #21 on: 03 March 2015, 16:05:45 »
Will it be good enough to take off wheel nuts ? And be good enough for bodywork spraying  :-\
Omegatitis
« Reply #22 on: 03 March 2015, 16:54:06 »
The air gun may struggle, might be better to invest in better gun. And hose.
« Reply #23 on: 03 March 2015, 17:23:35 »
Yes (with a decent gun as TB says, my Ingersoll Rand one works fine on wheel nuts). And yes for single panels but not a whole car without taking the odd breather.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #24 on: 03 March 2015, 19:09:40 »
Always fancied an air ratchet and as we have comp. air at work . . .
Mine's still going strong after 25 years: http://www.powertoolsalesuk.com/cp828h.html
As is this mother: http://www.powertoolsalesuk.com/cp734h-chicago-pneumatic.html
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #25 on: 04 March 2015, 17:52:11 »
That's identical to the Clarke & Airtools ones that machine mart are trying to shift for £100 more
Webby, cheap air ratchets will be a disappointment after your battery gun
TBH TB, I don't want the gun.... was just considering the air ratchet just for making ease and speed of running down fasteners (not for breaking anything loose). Although when I think about it id then have to swap sockets over and its prob more hassle than its worth  :-\
RIP Paul Lovejoy
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« Reply #26 on: 04 March 2015, 22:57:46 »
I have an air ratchet and it coped quite well, has seen quite a bit of abuse too.
Only problem I have found with it, as with most air tools, noise.....
D.I.L.L.I.G.A.F...
« Reply #27 on: 05 March 2015, 09:42:47 »
Yup, air ratchets are noisy & slow.. though they have their uses.
I'd really like a cordless electric ratchet (not windy gun, ratchet) but they appear to be £300+ so.. I'll continue to use my wrist (same as other things, then) ;D
« Reply #28 on: 05 March 2015, 14:01:06 »
A lovely lunchtime image...
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #29 on: 05 March 2015, 15:11:50 »
Says the smelly 600 year old hobbit who eats raw fish and never washes...... ::)
Pages: 1 [2] 3  All   Go Up
