Author Topic: NCDC swap  (Read 6519 times)
hoj
  • BURY
NCDC swap
« on: 04 March 2015, 16:40:55 »
Can a 2013 be swaped with a 2015?
Is it straightforward?
Looking to add the "phone" option to my car which has the 2013 fitted
and presume I need a 2015 as I see these have the buttons on for a phone .....am iIcorrect?
3.2 Elite in Oyster
powerslinky
Re: NCDC swap
« Reply #1 on: 04 March 2015, 17:01:59 »
Not just a HU swap . . . . Telematics gubins to go in the glove box area & screen to be paired to new HU
Taxi Al will give you the full details when he reads your post  :y
Re: NCDC swap
« Reply #2 on: 04 March 2015, 18:32:53 »
Pretty much as Al says :y
Old 2013 and screen out.
New 2015, screen and telematics box (plus suitable glovebox) in, might need a different aerial/loom depending what is actually fitted to the car :-\
The HU, screen and telematics are all paired to each other so can't be swapped willy nilly... not only will they not work, they might never work again if you try :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: NCDC swap
« Reply #3 on: 04 March 2015, 19:39:47 »
You can in theory add a Telematics Unit (the glove box thing) to a 2013 HU, it will act as a 2015  but with 2013 buttons, the 2015 *,#, Red and Green headset buttons will work on the 2013 TP, Sat Home buttons etc. Downside is you need to source a Unpaired working Telematics, Cables, have the Code for the HU, know someone with a Tech 2 who knows what there doing.
So probably easier, just to source a working 2015 / Telematics Set Up and retrofit as the Two Al's have said (what is this a double act?, so goodnight from me and goodnight from him  ;))
powerslinky
Re: NCDC swap
« Reply #4 on: 04 March 2015, 19:46:23 »
 ;D ;D ;D  LOL !  . . . . .      bit early for a goodnight  . . . even I don't go to bed until 9 ;D ;D ;D ;D
    • 530D M Sport, 330i Coupe
Re: NCDC swap
« Reply #5 on: 04 March 2015, 19:48:42 »
You'll need to make up a loom between the telematics and the head unit as 99% it wont be in situ.
hoj
  • BURY
Re: NCDC swap
« Reply #6 on: 04 March 2015, 20:03:36 »
Cheers guys sounds a lot of work really think I'll just get as universal kit fitted
3.2 Elite in Oyster
Magwheels
    • 2.2 dti Elite saloon
Re: NCDC swap
« Reply #7 on: 04 March 2015, 21:22:07 »
Why not just get a second hand Nokia Bluetooth kit off fleabay?
Its got to be easier and cheaper.
Mine works a treat.
hoj
  • BURY
Re: NCDC swap
« Reply #8 on: 05 March 2015, 09:52:02 »
Looking on auction sites seems like I could get one quite cheap but noticed that most even wireless still have a CIG lighter socket wired
Didn't want wires showing really so would the wiring/plug be there somewhere behind the fasie/glovebox
3.2 Elite in Oyster
Magwheels
Re: NCDC swap
« Reply #9 on: 05 March 2015, 21:08:14 »
What? All you can see of mine is the rotary controller and that is mostly obscured by the steering wheel when driving.
If you like I will try and take a picky and post on here.
One of these will do you "Nokia CK-7W Bluetooth" although mines an earlier model (but free).
Mine is up under the glovebox (above the trim panel) and wired in directly to power, radio mute and phone speaker in from the original telematics/phone wiring into the NCDC213. Works a charm.
hoj
  • BURY
Re: NCDC swap
« Reply #10 on: 05 March 2015, 21:41:16 »
A PIC would most certainly be helpful magwheels
3.2 Elite in Oyster
Magwheels
Re: NCDC swap
« Reply #11 on: 05 March 2015, 22:39:50 »
I will take one tomorrow, though as mentioned there is not much to see as the main "gubbins" is up under the glovebox.
Magwheels
Re: NCDC swap
« Reply #12 on: 06 March 2015, 22:05:28 »
Not much to see really.
I now have it on push to answer but depending on phone it will self answer and read out callers and texts if wanted.
I just wanted a "hands free phone" with a little clutter on view as possible.
I stuck a Parrot kit in the wife's car which is all singing all dancing but I did not want a screen stuck up in the facia on mine!
road rage
  • Norwich UK
    • omega b
Re: NCDC swap
« Reply #13 on: 07 March 2015, 19:24:09 »
Do the TMC feature do anything on these Ncdc systems I have TMC displayed in the corner where gps symbol is but never had any info come up on the CID  have had it on classic fm to see if it do as it seems like that is the only station the support it.
Magwheels
Re: NCDC swap
« Reply #14 on: 07 March 2015, 19:42:50 »
I always have mine on DAB so have never even tried to use it.
As far as I am aware it doesn't work over here.
