Author Topic: coolant level  (Read 5117 times)
Ady
  • Poole
    • Omega 2.6
coolant level
« on: 07 March 2015, 10:31:53 »
My car is telling me that the coolant level is low but it's fine. Is this just a sensor or a sign of something worse?
Also can't seem to find the sensor on euro's website site.
All help is much appreciated.
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
Re: coolant level
« Reply #1 on: 07 March 2015, 10:33:47 »
Sensor isn't available on its own... New bottle needed for around £35
Re: coolant level
« Reply #2 on: 07 March 2015, 12:24:49 »
Wot e sed :y
Re: coolant level
« Reply #3 on: 07 March 2015, 12:52:47 »
£35 for a plastic bottle. :'(
I believe the yellow cap comes at extra cost. :'( :'(
Re: coolant level
« Reply #4 on: 07 March 2015, 13:14:12 »
About another tenner, but they're shiny and new 8)
Re: coolant level
« Reply #5 on: 07 March 2015, 13:49:35 »
So £45  for something that probably costs pennies to manufacture. Crooks.
Almost as bad as the cam cover gaskets.......£50 for a few strips of piss thin rubber. :(
Re: coolant level
« Reply #6 on: 07 March 2015, 13:50:56 »
Kitchen scourer brings them up like new. :)
Re: coolant level
« Reply #7 on: 07 March 2015, 15:48:17 »
Being single, I wouldn't know... ::)
flyer 0712
Re: coolant level
« Reply #8 on: 07 March 2015, 16:58:21 »
As long as you know the water level is ok....cheaper and easier to tap the end of the wiper stalk to get rid of the warning....very common fault.... :y
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: coolant level
« Reply #9 on: 07 March 2015, 17:24:21 »
You could look at it that way, or you could take the view that the water bottle with new sensor will keep the engine from over heating and seizing should the water leak out by telling you the level is low before damage occurs. (Although with the leaky cooling system on omegas, there's an element of crying Wolf about it as well)
Same with cam covers. They should keep the oil out of the plug wells and keep your ignition system from being destroyed.
Both are investments in reliability imo. And in the grand scheme of things, not that expensive.
These things don't last forever Dr. High miles and a hotter than most engine bay mean wear and tear.
One must spend some of ones millions to keep one in the manner to which one is accustomed. Mustn't one. ;)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Re: coolant level
« Reply #10 on: 07 March 2015, 17:29:54 »
When its cold, stick your finger in and give the sensor bit a good waggle. They are known to stick. Mine played up two years ago....waggled it, and ok since. And...yes it still works properly as I drained some coolant out the other day, and the dash warning came back on. Topped up and all well.
Worth a try, short term. :y
chrisgixer
  • Woking ham
  • Banned
Re: coolant level
« Reply #12 on: 07 March 2015, 20:47:23 »
Apologies. Yes indeed, try that first. Cold as Terbs says  :y
Re: coolant level
« Reply #14 on: 07 March 2015, 23:53:49 »
Just do lick your fingers after ffs... ;D
