Author Topic: Rear end refresh (steady now) - parts?  (Read 2410 times)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« on: 07 March 2015, 10:59:32 »
Since the explod is still sat with his arse skyward, I'm thinking of a full-on refresh while I'm under there.
So far Ive thought -
Poly bushes for the subframe
Bilstein B4s and Eibach springs
Braided brake lines
Pads and discs
Reconditioned calipers.
Its already got new handbrake cable... Anything else I should think about? Diff mounts?
Re: Rear end refresh (steady now) - parts?
« Reply #1 on: 07 March 2015, 12:21:42 »
Check the diff mounts carefully  :y
I have a plan afoot for refurbishment,  but they're not available except as used...
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #2 on: 07 March 2015, 12:25:07 »
You could also do the trailing arm bushes and anti-roll bar bushes.  You'll also want to free-off the adjusters on the tie-rod arms for when you come to have the geometry re-aligned.
I have a full set of braided hoses here that I bought from brake-lines.co.uk (VAU-4-179) will sell them for £70 inc. UK postage.
Also, have a factory refurbished N/S rear calliper (see here clicky) can do this with the brake lines for £175 inc. UK postage.
BTW, if you need new pins, etc. for the pads then the VX part number to order for the complete pads/pins/springs/shims kit is 9195058 - should cost £60 inc. VAT,  May sound pricey but I've seen people paying £50 just for the pins and springs!
« Last Edit: 07 March 2015, 12:28:44 by sjc »
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #3 on: 07 March 2015, 13:12:28 »
Re trailing arm bushes, I've never ever heard of these needing to be replaced. Never had anything to do with them as a result.
This could mean they never fail, or we are all driving around on buggered ta bushes. Interesting to see what you find if you go in there though :).
But do be advised that the excentric poly trailing arm bushes are NOT for the omega, as it has camber correction bars (rear tie tod adjusters) that rely on the softer rubber bushes to enable adjustment.
sjc
  • Alloa, Scotland
« Reply #4 on: 07 March 2015, 13:31:47 »
TBH, I haven't seen a failed set either, only suggested thinking OP might want the car 'like new' :)
And, yeah, avoid the poly ones on Omegas fitted with the rear tie bars.  Poly rear ARB bushes would be ok though but the rear ARB bushes are a PITA to get at - you have to drop the rear crossmember a long way down to get into them, probably easier on a ramp rather than axle stands.  Also worth checking the condition of the ARB link arms.
« Last Edit: 07 March 2015, 13:38:40 by sjc »
chrisgixer
  • Woking ham
  • Banned
« Reply #5 on: 07 March 2015, 13:55:43 »
Arb bushes and drop links never fail. They are quite different to the front (for those that haven't seen them) while poly might be a usable upgrade for those that desire it, I'm not sure they are available in poly for the rear roll bar system. ..,.Are they....? :-\
« Reply #6 on: 07 March 2015, 15:43:30 »
Not that I have seen :-\ Monaro etc use a slightly different method of attachment so are of no use to us :y
« Reply #7 on: 07 March 2015, 16:39:46 »
Going to come back to this when I'm on the PC. And MrsGK isn't looking at the prices... Ta chaps so far!
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #8 on: 08 March 2015, 16:00:05 »
Might want to chuck some new shocks on also if you're renewing everything
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #9 on: 08 March 2015, 16:00:56 »
Ignore that comment . . . Just saw the bilsteins on ya list  :y
RIP Paul Lovejoy
