Author Topic: Cambelt failure  (Read 4602 times)
Re: Cambelt failure
« Reply #15 on: 13 March 2015, 18:53:06 »
A nice cheap fix!
As Nick says above, they're easily flooded when started & moved to shuffle cars about ..... apparently Christmas is a busy time for recovery firms
Re: Cambelt failure
« Reply #16 on: 13 March 2015, 18:54:25 »
Happy Days!  :y
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
Re: Cambelt failure
« Reply #17 on: 13 March 2015, 19:50:04 »
Another Omega saved by OOF  ....terrific site :y
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Cambelt failure
« Reply #18 on: 13 March 2015, 19:50:24 »
Result........flooded.
Nick....champion mate.
Friend came round, tried the keys gingerly then said..'Thats not belt, it attempted to fire' albeit almost non existant...so he gave it the gun and away it went.
That's the clue, and is when I ask about what's actually happened since it was last used. I only bother with the 'flood clear' procedure if the pump fuse/relay/cut-off switch aren't obvious.
Micras are good for this, because if you're quick when it catches, you can stick the fuse back in and look smug knowledgeable.
I'm glad it was nothing serious. And you might want to consider 6 new plugs ASAP.
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Re: Cambelt failure
« Reply #19 on: 13 March 2015, 20:08:55 »
When I see you, either at Wycombe or in Kent, I'll get you a drink or a breakfast.  :y
Just been out to try it and it started sweet as a nut as normal.
What causes them to flood like that. I can't recall it ever doing that before, either of them come to that. ???
  • Chatham, Kent
Re: Cambelt failure
« Reply #20 on: 13 March 2015, 20:16:55 »
The cold start on an FI engine works by adding extra fuel, unlike a carb which reduces the airflow.
If you turn it off before the cold start has started to decay, it's still running quite rich. Then, if it doesn't catch the first time it turns over, you end up with wet plugs and your problem. This is why I distrust the long plug change intervals/infrequent servicing, as these seem to be the worst culprits.
So, ensure the ignition system is up to scratch, and don't turn it off  if it has only run for a few seconds.
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: Cambelt failure
« Reply #21 on: 13 March 2015, 20:21:21 »
Thanks for the explanation, Nick....grateful :y
Goes to show...you learn something every day ;)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: Cambelt failure
« Reply #22 on: 13 March 2015, 20:21:58 »
What a shorter period before new plugs you mean  :-\
