And another Corsa C question
Started by tigers_gonads, 14 March 2015, 13:10:29
tigers_gonads
Servicing the rear brakes / handbrake / cable.
What size is the centre nylock nut that holds the rear drum onto the shaft / back plate ?
Looks about 28mm but not sure  :-\  Whatever it is, I ain't got one so before I order a nice new impact socket for my collection, can somebody confirm the size please  :)
Also the handbrake lever has a distinct lack of spring on it but i'll be dammed if I can find one  ::)
For certain, its not on the back of the cable / drum  :-\
TIA  :)
Mr gonads.......a reputable VX dealer will happily sort this out for  £85 P/H plus VAT. :y
tigers_gonads
Quote from: Doctor Opti on 14 March 2015, 13:13:52
Never heard of one of them  ;D ;D ;D
Webby the Bear
Funnily enough I replaced a Corsa C hanbrake cable on Thursday @ the garage.
You pull up the gaiter round the handbrake and slacken the 10mm nut on the threaded rod. You may find adjusting this (tightening it down) will take out the slack you have.
Then if you want to replace the cable (the one at work had severed on the N/S) you lever out the securing cylindrical things in the middle of the car underneath. Then cylindrical things on each side about 10cm along the cable from the drum. And remove the whole thing and replace.
Try not to break the securing clips as I did  ::)
RIP Paul Lovejoy
tigers_gonads
Already took up a little slack using the 10mm nut  :y
The cable looks pretty new as is the off side rear bering from the looks of the dust cap.
The car is new to us so just working my way through the essentials and putting a few little thing right  :y
The off side handbrake shoe need adjusting.  Probably never set up when the bering was done  :(
As always with a new car to me, i'm going to pull off the drums and grind any lip off them / clean them up / grease where necessary before rebuilding it all back up again hence the socket needed for the hub nut  :y
Cheers anyway Webby  :)
Webby the Bear
In that case mate you'll probably find it is the adjustment of the shoes that's playing the havoc, assuming there's plenty of meat still on them.
I was always told that when they're set correctly (and the drum is placed firmly on) you should be able to spin it one full revolution before it stops on its own.
RIP Paul Lovejoy
tigers_gonads
Quote from: Webby the Bear on 14 March 2015, 14:38:55
That makes sense mate  :y
Just need a bloody socket that fits the hub nut now  ;D ;D
Webby the Bear
RIP Paul Lovejoy
tigers_gonads
Got a similar set somewhere
Got a feeling my old man has nicked  borrowed them and he is floating around the Caribbean near the panama canal at the moment   :-X :-X
lee4206
I'm 99% sure its a 27mm socket you need.
Lee.
tigers_gonads
Thanks Lee  :y
A few conflicting opinions of there in t'nternet land.
Some say 27mm, some say 28mm and a few say 1" 1/16 is a better fit  ::)
lee4206
It's definitely a 27mm.  I'm doing one as I type.
That makes no bloody sense at all lol.
tigers_gonads
#13
Cheers Bud
Ordered one last night but the corsa is going on the back burner for a week or so  ..............
The B4's have finally chuffin arrived for the omega so when the chassis paint arrives, its paint / replace most of the front suspension time  :y :y :D :D
Edit to say i've got the rear to sort too  ::)
The Sheriff
Quote from: Marks DTM Calib on 16 March 2015, 13:11:18
What?!! You're not challenging Webby, surely?  ;D
