Author Topic: AR25 Level Plug - can't shift it  (Read 6107 times)
  • Auckland
    • Mazda MPV
Re: AR25 Level Plug - can't shift it
« Reply #15 on: 15 March 2015, 21:31:30 »
The plug came out easily once I had ground the head down and drilled through it
  • Auckland
    • Mazda MPV
« Reply #16 on: 15 March 2015, 21:41:40 »
Personally though if i could physically fit a drain plug I would. Just like the idea of quick ATF changes  :)
It's not the drain plug that slows the ATF change, but the awkward procedure for refilling the bloody thing. Doing away with dipsticks is a truly stupid idea, and it's now spreading to engines.
I used one of these - £15 from screwfix. Filling the box was almost too easy, a little worried that I might have overfilled it  ::)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #17 on: 15 March 2015, 22:05:31 »
I have something similar, but it's the grovelling about under the car with the engine running whilst filling the thing up. That would have been avoided if you could just pour the ATF down the dipstick tube; a procedure that worked well for decades.
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #18 on: 15 March 2015, 22:09:29 »
"It's a sealed for life item sir"
  • Chatham, Kent
« Reply #19 on: 15 March 2015, 22:23:14 »
Sealed for life translates to Doesn't last as long and can't be repaired when it does fail. That will be £12,658,365,489,457,436,495 please. Which we really shouldn't have allowed.
« Reply #20 on: 15 March 2015, 22:24:10 »
Is there not a blank/plug in the body casting for a dipstick tube as per the 4l60 etc :-\
Guess that the issue then would be establishing the correct length of dipstick to measure fluid level...
  • Chatham, Kent
« Reply #21 on: 15 March 2015, 22:26:10 »
4L60 isn't the same casing if that's what you're alluding to. It's massive, as you would expect considering what it's fitted to.
chrisgixer
  • Woking ham
  • Banned
« Reply #22 on: 15 March 2015, 22:26:57 »
Whispers quietly so nobody hears (it was originally a Bmw box ) shhhhhh
« Reply #23 on: 15 March 2015, 22:29:34 »
Ah yes... Been Made Wrong... ::)
