Installing leisure batteries in loft
Started by Gaffers, 16 March 2015, 12:36:00
Taxi_Driver
I think I would be a tad concerned about how hot your loft gets in summertime.
I know mine gets a hot as a sauna if we get a few weeks of hot temps.....not sure a battery would appreciate those sort of temps  :-\
Gaffers
Quote from: Taxi Driver on 16 March 2015, 18:20:58
I too have misgivings about that.  It gets to about 40C in the height of summer up there which is about as hot as a yacht will in direct sun down below.  So not utterly convinced it is an issue although I will continue to investigate.
Just noticed the sun was out so I took a reading off a panel that I could disconnect and got 20.2v and 1A :o
I know that is peak but still, not bad for a panel slightly bigger than a sheet of A4.
Elevated temperature does two things for lead acid batteries:
1) Shortens life
2) Increases capacity
An engine bay can get to silly high temperatures, way beyond 40 degC
Gaffers
Quote from: Marks DTM Calib on 17 March 2015, 15:19:21
1) Shortens life
These are AGM :y
The Sheriff
Can't yer just get some fickin Duracell like the rest of us?
Quote from: Monsieur Guffer on 17 March 2015, 17:50:22
1) Shortens life
These are AGM :y
Makes pretty much no difference, that just describes the glass mat between the plates so as to minimise acid content.
