Author Topic: Temperature gauge on the up?  (Read 2422 times)
woolley11
  • York
    • 3.0 MV6 auto
« on: 18 March 2015, 22:02:40 »
My 3.0 MV6 temperature gauge shows average/ middle reading  when driving along with no traffic in front. But if I follow someone even at speed, the gauge goes upto 100. I assume this is the lack of air ramming into grill.
Obviously in heavy traffic it moves upto 100 or so.
I use the heaters to pull heat out of the system but wondered if rad is silted or some other problem?
Omega 3.0 MV6 pfl
BMW Alpina B10 3.3 Touring
VW Mk1 Golf GTi Campaign, Triumph Dolomite Sprint
  • Auckland
    • Mazda MPV
Re: Temperature gauge on the up?
« Reply #1 on: 18 March 2015, 22:11:34 »
Definite possibility - either corrosion related  or possibly oil from a failing oil cooler.
Any signs of oil in the coolant header tank?
woolley11
  • York
    • 3.0 MV6 auto
« Reply #2 on: 18 March 2015, 22:21:03 »
Thanks for that - no oil apparent in the water system and no loss of oil from looking on dipstick level
I'll get it drained and flushed and see if that does any good  :y
Omega 3.0 MV6 pfl
« Reply #3 on: 18 March 2015, 22:37:46 »
Air con on or off and are all the fans working as they should?
  • Auckland
    • Mazda MPV
« Reply #4 on: 19 March 2015, 20:08:55 »
If the radiator is clagged up with hard deposits then a simple flush may not make much difference, you may need to use a descaler like Fernox. Check that the fans work first though (bear in mind that if the radiator is furred up then the thermostats in the radiator will also be covered in crud and less responsive than they should be)
woolley11
  • York
    • 3.0 MV6 auto
« Reply #5 on: 20 March 2015, 20:15:06 »
Thanks Andy H - will look into.  :y
Omega 3.0 MV6 pfl
