Author Topic: air leak  (Read 1433 times)
pauls
  • By the sea minehead
    • Bmw x3
air leak
« on: 21 March 2015, 10:41:01 »
I believe I have a air leak in my air suspension is there a quick way of checking this. Something like fairy liquid on the joints
Re: air leak
« Reply #1 on: 21 March 2015, 10:45:12 »
That will work :y
What symptoms?
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: air leak
« Reply #2 on: 21 March 2015, 11:40:55 »
There is a guide for testing operation. When elevated it's worth checking the bottom of the shock body for rust and oil leaks, especially the area under the bladders.
Air leaks. A spray bottle with washing up liquid and water helps. Along with the mark 1 ear 'ole. :y
I have some old ones here that are too rusty to be useful but they do hold air. So could swap the bad one out and fit one of those just to confirm, if nothing obvious is found. :)
pauls
    • Bmw x3
Re: air leak
« Reply #3 on: 21 March 2015, 11:55:09 »
I think it was the drivers side rear that you said kept dropping when you where running it up and down your drive. I have two rear shocks I got from robsey.
Al if you remember the compressor stayed on for a long time.
Re: air leak
« Reply #4 on: 21 March 2015, 14:37:26 »
Indeed it did...
Fit the shocks from Rob and then test it, then look for leaks if it's still playing silly buggers :y
