Author Topic: Those pain in the arse little plastic pins and a few other questions  (Read 1661 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
That hold on various bits of plastic on the side skirts / end panels and arches.
You know, the ones which always fall apart when you try and remove them  ::) >:(
Are they dealer only or can you get them off eBay or other places ?
Also, how do the painted side skirts come off ?
Looking at it its just a case of the bolts underneath and the end caps off  :-\
While i'm going to all this trouble, I may as well remove the skirts, rear bumper and liners so I can really go to town on any rust I can get too before it becomes a problem  :y
TIA  :)
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Side skirts have studs that press onto pegs welded to the body. So you have to prise them away from the body but without bending them too much or they will snap in half.
Once removed, and all screws and end caps removed, the skirt should pull off from the remaining hidden clips behind/along the length of the skirt.
chrisgixer
  • Woking ham
  • Banned
Ps,you should get back any pegs that are pushed trough to remove the end caps, once the skirts are off, so look out for those.
Nearly...
End caps can be removed after. For the sill cover... the little washer type things from underneath, then the single screw under front end. Steering on full lock to whichever side you're removing, so right for right... then slide the cover forward 2/3" and it will drop off.
For refitting, end cap on first, slot the cover into end cap, and from back to front put it upto the clips and slap it into place with your hand. Refit screw and bottom clips. Job jobbed :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Cheers for the info lads
Another thing on the list for when I have time  :y
