Author Topic: V6 Stalling  (Read 9074 times)
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: V6 Stalling
« Reply #15 on: 23 March 2015, 07:37:01 »
When you looked at plug on mine it seemed right but although put together the two halves hadn't been pushed fully home,so I suppose giving a weak connection.Once properly "clicked" together I had no further problems until cs packed in  altogether some months later
Re: V6 Stalling
« Reply #16 on: 23 March 2015, 07:46:34 »
Excuse me for suggesting that there might be an elephant in the room, but is the fuel light on?
Just asking, like ;)
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: V6 Stalling
« Reply #17 on: 23 March 2015, 23:10:37 »
full tank of fuel AL. Runs loverly until idle speed. revs cleanly and no miss fire. on the road drives fine but wont idle.
Jaguar XJ6
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: V6 Stalling
« Reply #18 on: 23 March 2015, 23:52:56 »
So this paper clip test.... ? :)
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
Re: V6 Stalling
« Reply #19 on: 24 March 2015, 13:23:09 »
How is your 4 bar pressure regulator plumbed in?
woolley11
  • York
    • 3.0 MV6 auto
Re: V6 Stalling
« Reply #20 on: 24 March 2015, 17:14:00 »
Cam shaft sensor ?
Omega 3.0 MV6 pfl
BMW Alpina B10 3.3 Touring
VW Mk1 Golf GTi Campaign, Triumph Dolomite Sprint
ffcgary1
  • Mitcham,Surrey.
Re: V6 Stalling
« Reply #21 on: 24 March 2015, 20:07:36 »
sjc the pressure regulator is a direct replacment of the original in the factory fit location.
Jaguar XJ6
ffcgary1
  • Mitcham,Surrey.
Re: V6 Stalling
« Reply #22 on: 24 March 2015, 20:08:26 »
woolley, do they ever fail?
Jaguar XJ6
woolley11
  • York
    • 3.0 MV6 auto
Re: V6 Stalling
« Reply #23 on: 24 March 2015, 20:44:43 »
Now and then  ;D
Omega 3.0 MV6 pfl
ffcgary1
  • Mitcham,Surrey.
Re: V6 Stalling
« Reply #24 on: 18 April 2015, 22:44:13 »
UPDATE,
Well after reading the codes via a paperclip test and failing to show any codes it finally got plugged into a tech 2 at my buddys dealership, again no codes stored and nothing showing of any concern on the live data whilst the engine was running with the aid of a little throttle. Plenun removed again and intake removed to check again for any spilit pipes and hoses including the brake servo pipe, all good. Replaced the icv valve rubber holder and plenum seal as i had bought it to replace a sloppy fit but no change in symptoms, wont idle when hot.
So decided to change the crank sensor with a new gen vx part fron vx, fitted said part and the car is now cured, idle rock solid for over an hour, so happy that it was the CS.
Seems i have found a new symptom of failing CS to add to the others that are known about.
VERY happy bunny.
Gary.
Jaguar XJ6
chrisgixer
  • Woking ham
  • Banned
Re: V6 Stalling
« Reply #25 on: 18 April 2015, 22:45:40 »
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: V6 Stalling
« Reply #26 on: 19 April 2015, 00:26:24 »
And never never ever any code for the failed CS
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: V6 Stalling
« Reply #27 on: 19 April 2015, 07:31:00 »
It is amazing how many strange symptoms are cured by a CS change on the V6's. Almost worth changing these first to eliminate! :-\ :-\ :-\
