Author Topic: hedlight problems bi xenon and alternative fix , people's opinions please  (Read 4370 times)
mr blaney
  • south tyne
    • omega skyline corsa
Ok so I have the actual xenon d2 h7 combo headlights  but a adjuster is broken and the lenses are faded  I was gonna just replace them with oem units till I found out there £208 plus vat each , eeek
So I'm debating in going the other route , buy new b2 2000-03 h1/h7 head lights , then just replacing the h1 with a hid unit bulb that should just plug into the oem xenon ballasts , total cost will be about £112
Can anyone see any issues as they still have the head light levellers in n washers for mot , bulbs will be the same just a diff setup kind of so light should be as equivalent if not better Fh
People's thoughts please ????
My advice would be to but some alloy adjusters to repair the internals and then sand and polish the plastic front to restore them.
The result then is OE headlights restored to original condition for circa 30-40 notes
Diamond Black Geezer
    • & a silly coupe coming...
If its just the adjuster that's broken, you can buy replacement solid metal engineered adjusters via this forum (or at least I hope you still can, I want some once the Mot's done) faded lenses are easily brought back to life with a cutting compound / wet n dry etc..
Alternatively there are many people who break and sell Xenons on here who should be able to help a fair hack cheaper than £208, or even £112.  :)
edit: must type faster  :D :D
mr blaney
  • south tyne
Sorry should have made it clearer,  the lense marks are on the inside also i believe scorched off high watt high beam bulbs , I've already polished the outers
Ergo imo there not ever gonna be clear as opposed to new units
  • Chatham, Kent
    • Ghastly 1.0l Focus
It's only worth buying used lamps if they already have the adjusters and don't need polishing. And are cheap. Good luck with that.
You have to remove the lens to replace the adjuster, which makes polishing the inside possible.
So that's the best way to go about it, as Mark said.
True, though it depends if he needs the car imminently - once he takes the headlamp apart he's committed, and has to reassemble that evening. If not, no headlamp = no drivey  :)
If he got a spare pair of lamps he can disassemble in his own time, and make the best job of it, doesn't matter if it takes a week, he's got time. On the other hand, if he can do it all in one evening, then no worries, no need to buy spare lamps.  :)
mr blaney
  • south tyne
Yes that is my other concern in my li e of work I'm basically on call 24/7 hence why I'm thinking buy replacement new lamps and a h1/hid 6000 k bulb kit and Install them to the ballasts I have in car already  then at a later date I can refurbished the originals as and when I get time
Can anyone confirm that you can 'Xenon-ise' standard lamps? ie: from the outside a FL omega with or without Xenons look visually identical - could mr blarney get 'any old' set of FL lamps, and only upon the actual act of taking his existing headlamps out, simply screw the Xenon 'pack/part/section' to his hitherto normal halogens? I mention as normal halogens are infinitely easier to get hold of than Xenons in good order.  :y
Merlindriver
  • Shropshire
  • Omega 3.2 Elite
There is bound to be an Omega with the original HID lights that is being broken somewhere. E-Bay?
HID lights will need the rest of the levelling system to function properly, or some messing around to get them to work with manual adjustment, which leaves the car "not strictly legal". Especially as the OP is looking for a quick turnaround that won't disable the car for too long, I'd just get the uprated adjusters and fix what he already has.
  • Chatham, Kent
I can't see the job taking more than an hour per lamp, from working to working.
That's a pretty quick turnaround?
Legally, no. The lens has to be type approved for HID use
And for info, no Omega was ever fitted with bi-xenon lights
mr blaney
  • south tyne
Bi xenon comes from the fact of d2 and h7 in one cluster same as what's in my spec 3 skyline head lights
Bi-xenon headlights have a HID bulb for main beam with a shutter mechanism. Omegas do not.
