Author Topic: Now need a 3.2 cambelt kit supplier  (Read 13146 times)
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« on: 01 April 2015, 18:13:39 »
Just priced one at the dealers and £178 quoted :o
A Contitech one would be much preferred
And price not that critical within reason
So over to you guys
 if anyone knows a good source it will be much appreciated :y :y
Spent most of today on the case without much luck :'(
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: Now need a 3.2 cambelt kit supplier
« Reply #1 on: 01 April 2015, 18:32:49 »
Tc gets it down to about £110/120 but still not cheap.
Most factors can help with a conti, gates or skf kit, so it's a case of phoning round, but it's important to get the right one re the backing plate and non/adjustable bottom roller on the 3.2's
hotel21
  • The Kingdom of Fife
« Reply #2 on: 01 April 2015, 18:32:56 »
Give Daz a shout Cliff.  As I recall, he has a contact or two.
Good to see you back as well. :y
steve6367
« Reply #3 on: 01 April 2015, 19:13:42 »
Buy parts buy get mentioned a lot with this question.
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #4 on: 01 April 2015, 19:48:02 »
Got mine from them and genuine conti  :y
« Reply #5 on: 01 April 2015, 20:07:19 »
http://www.eurocarparts.com/timing-belt-kit    :)
With any luck the £100 one will be the right one for your car.  :y
« Last Edit: 01 April 2015, 20:08:55 by Sir Tigger »
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #6 on: 01 April 2015, 20:12:17 »
Wonder what the difference is between the £138 Kit and the £100 Kit apart from price  ???
« Reply #7 on: 01 April 2015, 20:25:38 »
I think that the back plates are slightly different depending on the age of the car, so in theory you could buy the cheaper one and reuse the existing back plate.  :-\
However that might be a load of old cobblers that I've just made up.  :D  If I'm wrong I'm sure I'll soon be put straight and rightly so!  ;D
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #8 on: 01 April 2015, 21:52:32 »
The tensioner is completely different on the later engine  :y if you use buy parts by they ask for the engine number and supply the correct kit
« Reply #9 on: 01 April 2015, 21:58:25 »
To bloody expensive ;). And certainly only buy online for home delivery, as some stuff sits on their store shelves for years.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #10 on: 01 April 2015, 22:00:03 »
Good to know, I'll definitely need to be doing the cam belt myself this year, Where about's is the engine number located by the way? Can't say I've noticed it anywhere before.
  • Auckland
    • Mazda MPV
« Reply #11 on: 01 April 2015, 22:07:18 »
If you take the engine out, degrease the area around the oil filter and then give the block a good rub with emery cloth you should be able to make out the engine number.
Failing that it is printed on the registration document  :)
« Reply #12 on: 01 April 2015, 22:08:48 »
And a 3.2 will take the latest type, with non adjustable lower idler.
chrisgixer
  • Woking ham
  • Banned
« Reply #13 on: 01 April 2015, 23:04:38 »
 :D
« Reply #14 on: 01 April 2015, 23:09:13 »
How much is a good price then?  ???  ByPartsBuy are about the same for one but much cheaper for the other.  :-\
http://www.buypartsby.co.uk/buy/VAUXHALL/OMEGA/3.2/2002/__/54/engine/belts-tensioners/timing-belt-kits/
