Author Topic: auto to manual clutch/flywheel options  (Read 2802 times)
Michael Devlin
  • Longford, Ireland
    • 3.0v6 elite
« on: 07 April 2015, 19:57:57 »
I have bought a 3.0v6 auto which im intending to convert to manual. I was wondering what clutches and flywheels are compatible with the 3.0 engine, i know the gearboxes are universal. I was thinking of buying a 2.2 16v to get my manual setup from but will the clutch and flywheel fit my 3.0? Any help greatly appreciated
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: auto to manual clutch/flywheel options
« Reply #1 on: 07 April 2015, 21:03:49 »
As the V6 was available with a manual gearbox, why would you consider any other setup?
B-Buster
  • Netherlands
    • 3x Omega 3.0
    • OpelOmegaPortal (NL)
« Reply #2 on: 07 April 2015, 21:44:35 »
Won't be a fit, as the dual mass flywheel of the V6 has 8 mounting holes, the 2.0 and 2.2 only have 6 of those.
Did a motorswap in one of my Omega's, from 2.0 to 3.0 and keeping the manual of the 2.0.. had to replace the flywheel and clutch (bigger size as well).
« Last Edit: 07 April 2015, 21:46:41 by B-Buster »
Michael Devlin
  • Longford, Ireland
    • 3.0v6 elite
« Reply #3 on: 08 April 2015, 07:31:26 »
I looked up clutches on ebay an it appeared to me that the 2.5 3.0 and both diesels use the same clutch/flywheel setup, would i be right in assuming this they all said 240mm clutch disc
Reason i wanted to use 2.2 is because they are far easier to come by in rep of ireland and alot cheaper to buy
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 08 April 2015, 13:57:31 »
Use Vectra fly wheel and a spacer, from ebay. :y
Hoof'land storeman.
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #5 on: 08 April 2015, 14:53:10 »
A C20XE flat-type flywheel (lightweight when compared to the DMF), a factory/LUK clutch kit and a Retropower clutch spacer will do the job nicely.
PM with your requests.
« Reply #6 on: 08 April 2015, 15:30:26 »
As the V6 was available with a manual an automatic gearbox, why would you consider any other setup?
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #7 on: 11 April 2015, 17:02:16 »
If you want a solid flywheel instead of dual-mass, the one I used was from a V6 Cavalier (same on Calibra) with the Cavalier disk and the Omega pressure plate.  You can also use a C20LET clutch disk.
Be sure to have the correct sprung or unsprung clutch disk (sprung for solid flywheel, unsprung for dual-mass).  Either way use a 3.0V6 Omega pressure plate or you risk getting clutch slip.
Michael Devlin
  • Longford, Ireland
    • 3.0v6 elite
« Reply #8 on: 12 April 2015, 10:55:45 »
Yesterday I went and got myself a lsd diff and 3.0 flywheel with 8 mounting holes as mentioned above so i suppose its best to just get a new 3.0 clutch and pressure plate for it now :) so I'm assuming the 2.2 petrol gearbox and release bearing and gear linkages and all the clutch and brake setup will now be a straight fit once i have 3.0 flywheel clutch and pressure plate installed????
« Last Edit: 12 April 2015, 11:02:47 by Michael Devlin »
Michael Devlin
  • Longford, Ireland
    • 3.0v6 elite
« Reply #9 on: 16 April 2015, 22:14:01 »
What torque are the flywheel bolts to be set at??
