Author Topic: leaking radiator  (Read 4599 times)
flymofred
  • nr. Tunbridge Wells (Royal)
    • (53) 2.6 Elite Estate
leaking radiator
« on: 10 April 2015, 19:39:16 »
Well after having to pay up to get new rocker gaskets and coil packs fitted. I notice water dripping out the radiator!! The car is a v6 2.6 is it a major strip down to to get the rad out , as I'll have to do it myself after being left absolutely skint after the previous disaster. Thanks martinH
Re: leaking radiator
« Reply #1 on: 10 April 2015, 20:06:38 »
Where is it leaking from? Exactly...
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #2 on: 10 April 2015, 20:20:14 »
In a word, no, fairly straightforward. :y
« Reply #3 on: 10 April 2015, 20:44:20 »
Might not require replacement... but does rather depend on where the leak is :-\
flymofred
« Reply #4 on: 10 April 2015, 21:18:33 »
Looking the  engine bay it's on the right about midway down I think.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #5 on: 10 April 2015, 21:28:45 »
Have a read here of a recent Thread  :y
http://www.omegaowners.com/forum/index.php?topic=129008.0
« Reply #6 on: 10 April 2015, 21:42:17 »
If you mean the battery side, there are two thermoswitches... could simply be a failed seal on one of these... both are cheap and easy to replace.  :y
flymofred
« Reply #7 on: 10 April 2015, 22:23:01 »
I like the sound of leaky switches . Will check it out, no doubt knowing my luck I'll be back tomorrow for another option.
« Reply #8 on: 11 April 2015, 00:30:44 »
Check the drain plug at the bottom as well.  ;)  :y
    • 530D M Sport, 330i Coupe
« Reply #9 on: 12 April 2015, 18:12:43 »
Never seen one leak at the sensors, the drain plug can sometimes leak but usually after it's been disturbed. The one in my 2.6 was leaking where the plastic / abs side tank is joined to the main radiator. Only answer was a new radiator.
« Reply #10 on: 12 April 2015, 19:17:47 »
On an Omega I have seen leaky drain plug, leaky thermoswitch, cracked tank seam, and good old fashioned leaking core.
Pop the battery off for access/visbility and starting with the drain plug look for evidence...
If above the plug is dry, then the plug is the issue, if not move up to the next thing etc :y
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #11 on: 12 April 2015, 19:50:22 »
Possibles.
Drain plug seals. Easy.
Switch seals. (And they ARE dowty washers I don't care what any bigger says on here)
Or as on mine, the end cap seal.
Disintegrated radiator fins.
All except the top one, may as well swap the rad out for a good one given the amount of work required. Two new dowty washers on the switches, sorted.
But if a fiddle to get the rad in and out but basically straightforward. Possibly because I left the battery in.
flymofred
« Reply #12 on: 20 April 2015, 09:14:58 »
The leak is crack 1/2 way down the rad. there's bracket that's pulled away I stuck some Radseal in it. It worked the trade off is it now runs a lot hotter
« Reply #13 on: 20 April 2015, 10:35:00 »
If that's a coolant additive then you will rue the day you did that... :-X
flymofred
« Reply #14 on: 25 April 2015, 10:37:24 »
It was. So far so good. But I am on the lookout for a replacement radiator. I think it has upset the thermostat which has always run cold, but now  runs hotter  I can't swallow the the terrible cost of a Vauxhall garage Changing it. Hey ho
