Author Topic: drivers side indicator staying on permanently  (Read 1507 times)
howser1903
  • long eaton, nottinghamshire
    • 3.0 mv6
« on: 15 April 2015, 19:09:51 »
hi to all fellow omega owners
i am now on my second omega after owning a 3.0 elite before the head gasket went. i now have a 3.0 MV6 with the above problem, i also have the horn stuck on all the time and have had to remove the fuse to stop the neighbours killing me. Also i have had the interior lights stay on permanently too. All of these problems happened within 24 hours of each other, i have swapped all the relays in both omegas (as in the elite everything worked) and the only thing that seems to have been fixed is the interior lights. i have tried the hazard trick as suggested in previous posts but to no avail. so i am now stumped on the indicator and the horn if anyone can help me this would be very much appreciated in advance.
Re: drivers side indicator staying on permanently
« Reply #1 on: 15 April 2015, 20:38:05 »
Which horn? If you pull the horn relay, does it still sound? If yes, it sounds like an alarm issue... Tech 2 won't hurt, but check bonnet switch... There's an alarm horn next to the power sounder in addition to the main horn behind the front bumper...
