Pages: 1 2 3 4 5 [6] 7 8 9 10   Go Down
Author Topic: I hope this works  (Read 34076 times)
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
Re: I hope this works
« Reply #75 on: 27 April 2015, 07:54:53 »
I know but I need to do cam covers again anyway >:( :-[
« Reply #76 on: 27 April 2015, 09:18:43 »
Best thing is to acquire another box, soak it overnight in a bowl of petrol, then leave to dry in the sun, followed by a quick go in the dishwasher.
Don't tell Mrs danzigfan!  ::)  ;D
EMD
  • Noofhampton
    • 95t
« Reply #77 on: 27 April 2015, 10:09:42 »
Anyone got a part number for the breather box ? Probably not cheap  :-\
Omegatitis
danzigfan
« Reply #78 on: 27 April 2015, 10:41:37 »
You'll get the number on wednesday when I rip it out.... >:( :P ;D I went for a drive minutes aho again, came home and no smoke and no burnt oil smell ???  Pressure on gasket probably rises with rpm because I didn't pass 2000 rpm this time.
What if I try to clean and fix breather box only without touching cam gasket again?
EMD
  • Noofhampton
    • 95t
« Reply #79 on: 27 April 2015, 11:03:42 »
Worth a try an won't do any harm.. less hassle  :) You need long  arms ti reach box  :-\
I think mine needs taking off now  >:(
Omegatitis
« Reply #80 on: 27 April 2015, 11:03:49 »
Should be ok as the seals are new :y
Box is a metal lump so absolutely no reason not to use second hand ones and clean thoroughly before fitting... Common to all Omega era v6s :y
EMD
  • Noofhampton
    • 95t
« Reply #81 on: 27 April 2015, 11:06:00 »
What is part number for the proper sealant ?
Omegatitis
danzigfan
« Reply #82 on: 27 April 2015, 11:12:20 »
Oil Cooler Plate Sealer Part Number is = 93165267 and AFAIK it's the same for breather at the back
« Reply #83 on: 27 April 2015, 11:13:57 »
Indeed :y
danzigfan
« Reply #84 on: 27 April 2015, 11:17:36 »
How long does it take to remove wiper scuttle? I'll try it that way instead of plenum removal for the 5th time now
« Reply #85 on: 27 April 2015, 12:04:15 »
20 mins being careful :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #86 on: 27 April 2015, 12:37:10 »
Beware, the fasteners are not captive, and will head for the hills if the scuttle is lifted off with them still in place. Don't ask how I know this. :-[ :-[ :-[
danzigfan
« Reply #87 on: 27 April 2015, 12:39:32 »
Thanks guys, will bear that in mind :y
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #88 on: 27 April 2015, 13:50:18 »
As I need to remove plenum, injectors and all unnecesary stuff away that would be the easyest acces to the breather box remove I guess.
Just force I paper clip, or similar diameter item through the small hole in the breather box brass pipe, and dig out any crap in the large bore pipe. There's no need to go any further than that as far as clearing the alloy breather box goes. There is nothing to be gained by removing it.
There is a guide on this somewhere.
chrisgixer
  • Woking ham
  • Banned
« Reply #89 on: 27 April 2015, 13:54:38 »
Ps I have had the box off before. You have to destroy the rivet to open it. It's not complex just a baffel plate. Nothing more in there.
Just force something through to clear any blockage. :y
Pages: 1 2 3 4 5 [6] 7 8 9 10   Go Up
