Author Topic: 3.2 misfire  (Read 11664 times)
C20det
  • Belfast
    • 02 3.2 v6 Special
Re: 3.2 misfire
« Reply #15 on: 03 May 2015, 16:46:06 »
And there's the EML back on lol ....arghhh  >:(
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: 3.2 misfire
« Reply #16 on: 03 May 2015, 17:34:34 »
O2 sensor causing fuel trim malfunction on bank 1.
Replace O2 sensor bank 1 sensor 1
Genuine Bosch about £50 I guess?
chrisgixer
  • Woking ham
  • Banned
Re: 3.2 misfire
« Reply #17 on: 03 May 2015, 17:35:02 »
Assuming not a wiring problem of course.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: 3.2 misfire
« Reply #18 on: 03 May 2015, 17:39:54 »
« Last Edit: 03 May 2015, 17:47:31 by BIGtime »
chrisgixer
  • Woking ham
  • Banned
Re: 3.2 misfire
« Reply #19 on: 03 May 2015, 17:40:47 »
Have you got one eye shut? ;D
Steve B
  • Leicestershire
Re: 3.2 misfire
« Reply #20 on: 03 May 2015, 17:45:45 »
What you on about  :-X :-X
chrisgixer
  • Woking ham
  • Banned
Re: 3.2 misfire
« Reply #21 on: 03 May 2015, 17:50:27 »
;D
Mr Bigtime has edited his post which said, how much are they? (02 sensors ) ;D
:P
« Last Edit: 03 May 2015, 17:53:09 by chrisgixer »
Steve B
  • Leicestershire
Re: 3.2 misfire
« Reply #22 on: 03 May 2015, 18:03:12 »
;D
:P
Snitcher  ;D ;D ;D
C20det
  • Belfast
    • 02 3.2 v6 Special
Re: 3.2 misfire
« Reply #23 on: 03 May 2015, 18:44:22 »
I will check for any wiring problems & if not will proceed with genuine sensor as it was replaced by my motor factors probably cheap crap..
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: 3.2 misfire
« Reply #24 on: 03 May 2015, 18:53:19 »
Forgive me if I've got this wrong. But. . .
I would be doing what Al said in the first post before touching your O2 sensors. I.e. Look in to misfiring cis if it's dumping fuel in and there's no spark, the O2 sensor will pick that up as a too rich code.
Just my initial thoughts and again, sorry if that's wrong.  . . . Don't want to incur dtm's wrath again  ;D :-[
RIP Paul Lovejoy
chrisgixer
  • Woking ham
  • Banned
Re: 3.2 misfire
« Reply #25 on: 03 May 2015, 20:11:34 »
I've yet to come to a 3.2 Ecu on a new to me car, that didn't have a historic miss fire code in there somewhere. It's not showing a misfire on the second reading by all accounts. So codes cleared and what's returned...?
Present O2 sensor. Present fuel trim. All bank 1.
As said ignore 0420 0430 as normal for now. But the pre cat brings the light on hiding everything else to the driver. Fuel trim would be good to check  on live data as if it's over +/-25 then it will struggle to run.
Webby the Bear
  • Northampton
Re: 3.2 misfire
« Reply #26 on: 04 May 2015, 11:43:29 »
Ok then fair enough Chris. I clearly missed the bit where codes were cleared then re read.  :y
RIP Paul Lovejoy
chrisgixer
  • Woking ham
  • Banned
Re: 3.2 misfire
« Reply #27 on: 04 May 2015, 11:45:34 »
Er well no it's not been expressed, but the codes aren't present in the second list.
Webby the Bear
  • Northampton
Re: 3.2 misfire
« Reply #28 on: 04 May 2015, 12:19:34 »
 :y :y :y
RIP Paul Lovejoy
C20det
  • Belfast
    • 02 3.2 v6 Special
Re: 3.2 misfire
« Reply #29 on: 04 May 2015, 19:46:55 »
Just checking I'm correct here bank 1 sensor 1 would be the pre cat sensor from cylinders 1, 3 and 5? Am I right?
Pages: 1 [2] 3 4  All   Go Up
