Author Topic: 3.2 misfire  (Read 11663 times)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: 3.2 misfire
« Reply #30 on: 04 May 2015, 20:08:29 »
Just checking I'm correct here bank 1 sensor 1 would be the pre cat sensor from cylinders 1, 3 and 5? Am I right?
Yes you are correct,bank one sensor two is the downstream sensor which throws the 0420/30 codes,that's the sensor that needs moving to after the main cat.
other rides
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: 3.2 misfire
« Reply #31 on: 04 May 2015, 20:43:51 »
Correct
C20det
  • Belfast
    • 02 3.2 v6 Special
Re: 3.2 misfire
« Reply #32 on: 04 May 2015, 21:13:51 »
Okay so il move that sensor to after the cats but will this solve my problem? Take it I still need to replace the pre cat sensor then with a genuine Bosch.
Are these sensors all the same or different? Just I was reading that the pre cat sensors are usually used for fuel control & main catalytic converter oxygen sensors for reading amount of 02 used?
I'm confused abit with these as maybe I've got the wrong sensor as I just asked for an 02 sensor at the motor factors.
chrisgixer
  • Woking ham
  • Banned
Re: 3.2 misfire
« Reply #33 on: 04 May 2015, 22:54:36 »
Ignore 0420/30 for now. That's sensor 2.
You need to fix sensor 1.
There are no cats between the engine and sensor 1. So sensor 1 is purely concerned with exhaust gas created by the fuel/air mix. It's reporting the fuel air mix incorrectly, so the ecu is trying to "trim" the mixture by adding or subtracting a % to the normal injector timing duration. So your getting a fuel trim code as well.
Sensor 2 is AFTER the much smaller pre cat. So it's expecting to see some cleaner gasses (pre cats are there related to cold starting emissions in the States I think. Whatever, it was a crisp idea.) But because the PRE cats are old/small/have an exceptionally hard life the catalyst wears and becomes inefficient, as the codes says. Moving sensor 2 to a location AFTER THE MAIN cat, restores the efficiency sensor 2 expects to see. So 0420/30 codes disappear, the light stays off, and you can then see when the light comes on for a "genuine" fault, like a dodgy O2 sensor or a misfire etc....
chrisgixer
  • Woking ham
  • Banned
Re: 3.2 misfire
« Reply #34 on: 04 May 2015, 23:00:10 »
As Webby says though, it can do no harm to check (via the pedal trick, not a lesser known code reader, however expensive) there are no misfire codes listed.
I would advise doing so before purchasing a new sensor as that could complicate matters, as the codes "could" be a result of the miss fire, not other way round. I don't think so, as the ecu shuts down a misfiring cylinder on the drive by wire cars. But I don't want to waste your money advising a new sensor if it's not needed due to a diagnosis potentially based on half the available info. :)
C20det
  • Belfast
    • 02 3.2 v6 Special
Re: 3.2 misfire
« Reply #35 on: 05 May 2015, 17:23:36 »
Okay thanks I will try moving sensor 2 to a location after the cats, and see what the pedal trick says after I do so
Cheers guys
C20det
  • Belfast
    • 02 3.2 v6 Special
Re: 3.2 misfire
« Reply #36 on: 05 May 2015, 19:21:33 »
I also tried changing bank 1 sensor 1 with bank 2 sensor 1 to see if it would bring up sensor 1 on bank 2 was just trying to rule out if it was a faulty sensor but still reading bank 1 sensor 1, so hopefully at the weekend I will get sensor 2 moved location after the main cat my friend is good with a welder so should be no problem
Is it possible for me to post pictures being a newbie?
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: 3.2 misfire
« Reply #37 on: 05 May 2015, 20:01:03 »
Think posting pictures is no problem.Only thing you can't post until you hit at least 250 post count are for sale ads.
C20det
  • Belfast
    • 02 3.2 v6 Special
Re: 3.2 misfire
« Reply #38 on: 13 May 2015, 01:09:40 »
Hi guys
So on Sunday night I relocated bank 1 sensor 2 to after the main cat and started her up but light  was still on, I then reset it with the computer in work and drove it for about 70miles & just there tonight the light had came back on again but I have to say it was under abit of pressure I was driving up a bit of a hill in 3rd around 4000-4500rpm when it came on & now I'm getting these codes.
0130
0150
0430
0120
0170
0300
0201
Any ideas
Thanks, Carl
P.S I took a few pictures of my sensor relocation but I don't know how to upload photos yet 😏
Re: 3.2 misfire
« Reply #39 on: 13 May 2015, 01:31:22 »
Seek and ye shall find...
http://www.omegaowners.com/forum/index.php?topic=90594.0 ::)
Don't know what you've done, but you've really pissed off the car :-\
In no particular order...
Bank 1 O2 sensor 1
Bank 2 O2 sensor 2
Random multiple misfire
Throttle pedal position sensor
Bank 1 fuel trim
Cylinder 1 fuel injector
Bank 2 cat efficiency
C20det
  • Belfast
    • 02 3.2 v6 Special
Re: 3.2 misfire
« Reply #40 on: 13 May 2015, 18:13:24 »
I really I'm confused now lol, as I just got into the car after work & the EML light wasn't on??
I just put in onto the computer and was bring up
Cylinder 3 misfire detected
Cylinder 5 misfire detected
But they say "Not Present"
Mmmm Strange one
Re: 3.2 misfire
« Reply #41 on: 13 May 2015, 19:25:11 »
What code reader? Pedal trick is more reliable than "My Naff Code Reader"...
C20det
  • Belfast
    • 02 3.2 v6 Special
Re: 3.2 misfire
« Reply #42 on: 15 May 2015, 00:39:01 »
2014 Autel MaxiSys
These codes:
0130
0150
0430
0120
0170
0300
0201
Was from the pedal trick but now the eml light is out 😏
Re: 3.2 misfire
« Reply #43 on: 15 May 2015, 01:39:41 »
Bulb blown...
C20det
  • Belfast
    • 02 3.2 v6 Special
Re: 3.2 misfire
« Reply #44 on: 16 May 2015, 21:16:37 »
Right, would that cause this you think
Pages: 1 2 [3] 4  All   Go Up
