Author Topic: oil cooler cover plate  (Read 2118 times)
smartrs
  • out in the sticks
« on: 25 April 2015, 14:14:12 »
Where can I get just the oil cooler cover plate from mines corroded and leaking alot but I can't seem to find anywhere that just does the plate
Re: oil cooler cover plate
« Reply #1 on: 25 April 2015, 14:42:03 »
Just the plate is a false economy... Buy the cooler kit, four dowty washers and grey sealant and follow the guide here :y
Sealant requires 24 hours to set before refilling with coolant.
Be prudent to change the thermostat and transfer pipe whilst you're there :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 25 April 2015, 19:25:03 »
As above. :y
Hoof'land storeman.
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #3 on: 25 April 2015, 21:49:21 »
As above above  :y because sure as eggs are eggs the cooler will let go.  >:(
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #4 on: 25 April 2015, 22:43:33 »
If it's corroded the cover plate from the inside, the coolant needs replacing for the correct mix, as it will be corroding everything else within the cooling system, including oil cooler, matrix, radiator, block etc etc....
