Ac fans.
Started by chrisgixer, 25 April 2015, 23:14:11
DrAndyB
Quote from: steve6367 on 26 April 2015, 12:59:32
Brackets are ok on the linked replacement and cooling rad goes in and out no problem - just slight bend required in pipes from the drier to match those on the car  :y
Hope goes well.  Here is the original one which was removed from mine  :D  I recon I got my money's worth after 15 years !!!
I think I found why the A/C was not as "Cold" as it used to be !!!!!  Not shown up as good on pic, but bottom left patch is bright GREEN !!!
New one fitted as identical, even down to the GM Delphi hologram sticker and Part number :)  Car ICE cold now I need my coat to driver her   8)
When you clean out the 10 or so years of leaves and muck from between the fans and the condenser and the condenser and the coolant rad it's amazing how much more stable (and lower) the coolant temp sits!
Those two front fans for the condenser also do a great job of keeping the temp stable in stop start traffic in the summer.  :y
chrisgixer
DrAndyB
Quote from: VXL V6 on 26 April 2015, 16:31:41
:y Definitely  :y  Temp rock solid now.
Touch something wooden, and that is all the niggles on the old Girl sorted  :y
Freshly washed & waxed again and the old girl scrubs up well  :)  Better go and tuck her up in the garage under her blanket  ;)
Mr.OmegaMan
Fitted the A/C condenser and fitted the rad an all the gubbins back today took 2 hours at a leisurely pace, The radiator actually went in better than the job I had removing it, Condenser didn't require much of an effort to get everything lined up either  :y
The old condenser is most definitely the original an is clearly leaking, Leaves an stuff had congealed with the green stuff.
Just in time also been a sunny day, Only just started to rain.
chrisgixer
Well, ac guy just left. Had his yellow goggles and uv lamp on it. Condenser in good nic structurally, but it's got a hole in it half way up on the drivers side.
Not as simple as swapping as shrader valve. Sadly. :(
biggriffin
Quote from: chrisgixer on 26 April 2015, 18:47:48
http://www.autoairconparts.co.uk/shopby?find=vauxhall-omega-b-2003-3-2-v6-petrol-manual-automatic-2096643
Does seem to be as the ac links in parts section. :y
If your thinking of buying that condenser,make sure it comes complete with the dryer,as they show it separately,which the omega doesn't do. Should come fitted.
Hoof'land storeman.
DrAndyB
Quote from: biggriffin on 28 April 2015, 07:42:04
I have a 15 year old GM one going free  ;D ;D ;D
