Author Topic: WTD 2.2 MAF  (Read 2796 times)
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
WTD 2.2 MAF
« on: 26 April 2015, 17:39:12 »
As above on 03 estate
Had the dreaded P1555 code for a while. Have swapped cam sensor, throttle body and checked breathers even tried Lambas must be the MAF although car runs fine
Please reply or PM with costs
TIA
Phil
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: WTD 2.2 MAF
« Reply #1 on: 26 April 2015, 18:34:51 »
TIA
Phil
Thats not a MAF code
SIR Philbutt
    • PJB Home Services
Re: WTD 2.2 MAF
« Reply #2 on: 26 April 2015, 20:22:38 »
From the maintenance guide
P1555   Throttle Position Sensor (TPS) Load Signal not Plausible with Engine Load
The Autel i'm using (and some web lookup's) says this after setting it as a Vauxhall
Throttle Position sensor/Mass Air Flow sensor – Implausible Signal
After all that i have done the MAF is only thing left
What would you suggest Bigtime? although this is not the right section perhaps PM
Steve B
  • Leicestershire
Re: WTD 2.2 MAF
« Reply #3 on: 26 April 2015, 21:49:46 »
On my 2.2 i had these codes.
P0170 (2) lean exhaust-not present
p1555 (0) throttle position sensor (tps) load signal not plausable with engine load-not present
p0340 (4) camshaft position sensor circuit no signal-not present
p1700 (0) svs via can-not present
p0335 (8 ) crankshaft sensor incorrect signal-not present
After fitting new GM cam sensor, I had these codes.
P1555 - Throttle Position Sensor (TPS) Load Signal not Plausible with Engine Load  - Not present
P0170 - Lean Exhaust - Not present
After doing the TPS and breather guide exactly how the guide says I had no more codes..
SIR Philbutt
    • PJB Home Services
Re: WTD 2.2 MAF
« Reply #4 on: 26 April 2015, 22:22:30 »
So, as I said, done that, been there, no alternative, need to see if it's the MAF - Thanks for the info
Still want one, Anyone out there got one ????
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: WTD 2.2 MAF
« Reply #5 on: 26 April 2015, 22:35:03 »
Have you tried Steve at Omega spare parts? If no one on here has one might be with giving him a bell  :y
SIR Philbutt
    • PJB Home Services
Re: WTD 2.2 MAF
« Reply #6 on: 26 April 2015, 23:08:31 »
Thanks will give it go  :y
steve6367
Re: WTD 2.2 MAF
« Reply #7 on: 27 April 2015, 09:29:56 »
I had issues on my 2.2 and after trying the 'known good' route only a new VX MAF fixed the problem - I'm not sure if they all start to fail with miles?
They are not expensive from VX with TC.
Steve
